Listening to only 127.0.0.1:8080...
Hi all,
At last update, it seams the MM only listens to 127.0.0.1:8080 if I have set [] in the ipWhitelist.Here is the “start” of the mirror:
[STREAMING] Now streaming realtime logs for [all] processes 0|mm | Starting MagicMirror: v2.1.3-dev 0|mm | Loading config ... 0|mm | Loading module helpers ... 0|mm | Initializing new module helper ... ...All is starting ok and the mirror shows up on the local screen.
But it’s not available from any other IP.The start of my conf…
var config = { port: 8080, ipWhitelist: [], language: "sv", timeFormat: 24, units: "metric",And the listing ports (IPs) with netstat:
pi@MagicMirror:~ $ netstat --tcp --listening --programs --numeric (Not all processes could be identified, non-owned process info will not be shown, you would have to be root to see it all.) Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name tcp 0 0 127.0.0.1:8080 0.0.0.0:* LISTEN 3486/electron.js ... (removed the other ports in the list) ... pi@MagicMirror:~ $As you can see it’s only listening on 127.0.0.1:8080…
What have I missed/done?I can no longer access the /remote.html (for example) or any other “service” on the mirror from another machine.
Best regards Snille
It seems that you need to specify an IPv4 “address” in config, like this:
var config = { ipWhitelist: [], address: "0.0.0.0", }Worked for me…
