    JSON-RPC need help
    3 Posts 2 Posters 2.3k Views 2 Watching
    • T Offline
      tbe
      i´m a beginner with javascipt and need help . how can i call the json-rpc function ( getData ) to get
      data from API and how can i parse it, to display the result an MM.
      the result of the call should be an JSON-RPC string .
      	getData : function(){
      		var self = this;
      		var json = "http://xxx.xxx.xxx.xxx:3777/api/";
      		var retry = true;
      	      var HTTP = new XMLHttpRequest();
      		    HTTP.open("POST",json,true);
      		    var rpc = JSON.stringify({"jsonrpc":"2.0", "method":"GetValue", "params":[18697], "id":0});
      		   HTTP.setRequestHeader("Content-type", "application/json");
      		   HTTP.send(rpc);
      Thanks Thomas
        j.e.f.f Project Sponsor Module Developer @tbe
        @tbe You need to add an event listener to react to the response. example:
        HTTP.onreadystatechange = function() {
          if (HTTP.readyState == 4 && HTTP.status == 200) { //response complete and OK
            //do something with HTTP.response;
          } else if (HTTP.readyState == 4) { //response complete but some error
            console.log("Error: " + HTTP.status + " " + HTTP.statusText);
        Alternatively you can add individual event listeners for different states:
        HTTP.addEventListener("progress", updateProgress);
        HTTP.addEventListener("load", transferComplete);
        HTTP.addEventListener("error", transferFailed);
        HTTP.addEventListener("abort", transferCanceled);
        Full documentation on the XMLHttpRequest object here:
        https://developer.mozilla.org/en/docs/Web/API/XMLHttpRequest
        • T Offline
          tbe
          Thanks. But i have an other problem.
          The JSON request works per curl on console, but in js : "net::ERR_EMPTY_RESPONSE "
          Curl :
          curl -i -X POST -H "Content-Type: application/json" -d "{\"jsonrpc\": \"2.0\", \"id\": \"0\", \"method\": \"GetValue\", \"params\": [18697]}" http://xxx.xxx.x.xx:3777/api/
          but in the MM-JS-Script don´t work. Looks like the json parameter don´t work.
