    MMM-PublicTransportDB
    6 Posts 4 Posters 3.3k Views 4 Watching
    • T Offline
      Tekki
      I have installed the module MMM-PublicTransportDB and adjusted the Config.
      After a reboot this mirror appears at the module position only Loading …
      What do I have to adjust to make the module work?
      Here is my config
          module: 'MMM-PublicTransportDB',
          position: 'top_right',
              stationId: 8000139,
              hidden: false,
              ignoredStations: [],
              excludedTransportationTypes: '',
              delay: 10,
              interval: 120000,
              departureMinutes: 300,
              maxDepartures: 15,
              marqueeLongDirections: true,
              showColoredLineSymbols: true,
              useColorForRealtimeInfo: true,
              showTableHeadersAsSymbols: true,
              maxUnreachableDepartures: 3,
              maxReachableDepartures: 7,
              fadeUnreachableDepartures: true,
              fadeReachableDepartures: true,
              fadePointForReachableDepartures: 0.25
      • U Offline
        Ultimatum22 Module Developer
        Are there any errors in the linux console? And in your browser, open the console with f12 in a chrome browser while you are on your MM page.
        • T Offline
          Tekki
          Attached is the output in the console.
          Initializing MagicMirror.
          translator.js:197 Loading core translation file: translations/en.json
          translator.js:219 Loading core translation fallback file: translations/en.json
          loader.js:182 Load script: modules/MMM-PublicTransportDB//MMM-PublicTransportDB.js
          module.js:414 Module registered: MMM-PublicTransportDB
          loader.js:152 Bootstrapping module: MMM-PublicTransportDB
          loader.js:182 Load script: vendor/node_modules/moment/min/moment-with-locales.js
          loader.js:182 Load script: modules/MMM-PublicTransportDB//./vendor/bluebird-3.4.5.min.js
          loader.js:157 Scripts loaded for: MMM-PublicTransportDB
          loader.js:197 Load stylesheet: modules/MMM-PublicTransportDB//style.css
          loader.js:159 Styles loaded for: MMM-PublicTransportDB
          loader.js:161 Translations loaded for: MMM-PublicTransportDB
          loader.js:197 Load stylesheet: css/custom.css
          :8080/modules/MMM-PublicTransportDB//MMM-PublicTransportDB.js:29 Starting module: MMM-PublicTransportDB
          main.js:422 All modules started!
          module.js:117 MMM-PublicTransportDB received a system notification: ALL_MODULES_STARTED
          module.js:117 MMM-PublicTransportDB received a system notification: DOM_OBJECTS_CREATED```
          • T Offline
            Tekki
            I found the following message in the console.
            Transportation fetcher created. (Station ID: 8000139)
            (node:5048) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 1): TypeError: Cannot read property 'name' of undefined
            (node:5048) DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code
            Can someone help me?
              Josch
              Hey,
              I don’t know if it is still a problem, but I had the same errors. So I looked into it and found that some return value model porbably changed. I created a pull request from my version which is working:
              https://github.com/olexs/MMM-PublicTransportDB/pulls
              Maybe this helps someone someday ;)
              Cheers,
              Josch
              • K Offline
                knubbl
                Are u still working on an offline List for Staton IDs?
