    Error installing MagicMirror
    3 Posts 3 Posters 2.9k Views 3 Watching
    • Y Offline
      yours.mukul
      I got following warnings during installation
      npm WARN stylelint-config-standard@17.0.0 requires a peer of stylelint @^8.0.0 but none was installed
      npm WARN grunt-stylelint@0.9.0 requires a peer of stylelint @^8.0.0 but none was installed
      npm WARN stylelint-config-recommended@1.0.0 requires a peer of stylelint @^8.0.0 but none was installed
      Unmet peer dependency stylelint@^8.0.0
      UNMET peer dependency stylelint@7.13.0
      npm WARN prefer global coffee-script@1.10.0 should be installed with -g
      npm WARN prefer global jsonlint@1.6.2 should be installed with -g
      npm WARN prefer global colorguard@1.2.0 should be installed with -g
      • G Offline
        greda
        Did you download the version:
        RASPBIAN STRETCH WITH DESKTOP ?
        I advise you to see this too: https://forum.magicmirror.builders/topic/4596/help-to-install-magicmirror
        Good luck
        1 Reply Last reply Reply Quote -1
        • U Offline
          Ultimatum22 Module Developer
          These are not errors but known warnings. What is your problem, doesn’t it work and what doesn’t work because this is probably not a blocking installation error.
