Monitor with PIR-Sensor does not turn off
I am building my first MM and have a problem with the PIR-Sensor.
What have I done:
Installing wiringPi
1git clone git://git.drogon.net/wiringPi
2cd wiringPi
3git pull origin
4./build
Installing the PIR-Module
https://github.com/paviro/MMM-PIR-SensorConfiguring
config.js
like this{ module: 'MMM-PIR-Sensor', config: { sensorPIN: 23, powerSaving: true, } },
Connect the PIR to the raspberry like this
https://www.tutorials-raspberrypi.de/wp-content/uploads/pir.pngI am waiting about one, two minutes, but unfortunately the monitor does not turn off.
Does somebody has any idea?
Thanks in advance.
Klinge -
Yesterday, I got the solution. It is very simple. I had a wrong description of the PIR-Sensor. GND and VCC were interchanged. So I interchanged the cable and it works.
I have had exactly the same mistake on my side, wiring was wrong. It did not kill the sensor but it’s output status was always high. Also I had the mixed up SensorPin and the acutally Pin Number on the Pi.
