    How I got my Magic Mirror working on a Raspberry Pi 0 (zero)
    raspberry pipi0zeropizeropi1
    204 Posts 47 Posters 671.3k Views 47 Watching
      SebTota
      Did anyone get this working on the Pi Zero or Pi Zero W after the new update?
      H 1 Reply Last reply
      • H
        Hawking @SebTota
        @SebTota
        Which updates are you referring to? I’m still using Raspbian Jessie Light (I didn’t use the image provided in this thread but my own installation and didn’t update so Stretch yet), which is up to date (according to sudo apt-get update && sudo apt-get upgrade) and the latest version of MagicMirror (according to cd ~/MagicMirror && sudo git pull) and don’t see any (new) issues on my Pi Zero W.
        What are your problems?
          SebTota @Hawking
          @Hawking I get an error saying that modules/color is missing or something like that. I’ve been working on it for 3 days but can’t get it to work.
          • H
            Hawking @SebTota
            @SebTota
            • Do you also get this error if you use a very minimal config file like
            var config = {
                    port: 8080,
                    language: "en",
                    timeFormat: 24,
                    units: "metric",
                                    module: "clock",
                                    position: "top_left"
            If this works, you can step by step add the modules you want and see which one causes the problem.
            • The exact error message would be helpful for an analysis.
              SebTota @Hawking
              @Hawking
              module.js:339
              throw err;
              Error: Cannot find module ‘express’
              at Function.Module._resolveFilename (module.js:337:15)
              at Function.Module._load (module.js:287:25)
              at Module.require (module.js:366:17)
              at require (module.js:385:17)
              at Object. (/home/pi/MagicMirror/js/server.js:8:15)
              at Module._compile (module.js:435:26)
              at Object.Module._extensions…js (module.js:442:10)
              at Module.load (module.js:356:32)
              at Function.Module._load (module.js:311:12)
              and then the browser loads and says it cannot find http://localhost:8080
                SebTota @SebTota
                @SebTota I went to my old image from before the update and thats still working fine, but when I updated it, it again had the error come up. The only difference is last time I did the update it said Error: Cannot find module ‘colors’
                • H
                  Hawking @SebTota
                  @SebTota
                  I still don’t understand what update you are referring to.
                  Both error messages sound like there are modules missing (either “express” or “colors”).
                  What happens if you do
                  cd ~/MagicMirror && sudo npm install
                  cd ~/MagicMirror/vendor && npm install
                    SebTota @Hawking
                    @Hawking My MagicMirror has been sitting for a long time. When I recently finished the frame to get the computer display and rpi zero out of my closet I booted the rpi zero and on the top of the display it said A New Version of Magic Mirror is available or something along those lines. So I went into the MagicMirror folder and used the command “git pull && npm install” as specified in the README file of MagicMirror.
                    • H
                      Hawking
                      @SebTota said in How I got my Magic Mirror working on a Raspberry Pi 0 (zero):
                      Have there been errors when you did so?
                      I got
                      npm WARN lifecycle magicmirror@2.1.1~install: cannot run in wd %s %s (wd=%s) magicmirror@2.1.1 cd vendor && npm install /home/me/MagicMirror
                      Thats why I then did
                      in addition (see my post above). Maybe this also solves your problem.
                        SebTota @Hawking
                        @Hawking Sorry to keep bothering you but I ended up making it work with the two commands you told me to do. Now my problem is when the Pi Zero W is booting it connects to the WiFi but when magic mirror boots the pi disconnects.
                        • H
                          Hawking @SebTota
                          @SebTota
                          Just to make sure that I understand the problem correctly:
                          You see the MagicMirror on the screen (Clock running etc). but you can no longer connect to the Pi Zero (using eg. ssh)?
                          Just as a test:
                          What happens if you disable the MagicMirror from autostart (for example by moving the MagicMirror start script from /etc/init.d/ to your home directory) and start it manually while you are already logged in? I don’t know your exact setup or your Linux knowledge, if you need further help how to do this, just let me know.
                            SebTota @Hawking
                            @Hawking I actually eventually got it working. Thanks so much for all your help!
                            • H
                              hoggboss22
                              Hello everyone.
                              I’ve followed the instructions and did everything in the comments (all 12 pages) to make sure I am doing them right. I was able to see MM2 thru the browser but on my screen, it is showing white screen.
                              Loading config ...
                              Loading module helpers ...
                              All module helpers loaded.
                              Server started ...
                              Starting module: newsfeed
                              Ready to go! Please point your browser to: http://localhost:8080
                              { [Error: listen EADDRINUSE :::8080]
                                code: 'EADDRINUSE',
                                errno: 'EADDRINUSE',
                                syscall: 'listen',
                                address: '::',
                                port: 8080 }
                              mind helping me out with this?
                              ? 1 Reply Last reply
                                A Former User @hoggboss22
                                @hoggboss22 your mm seems being excuted multiple. Common pitfal is that more than one browser are opened.(maybe your previous test running?)
                                Or your machine is already using port 8080.
                                Kill all browsers(and node or npm) and restart. Or change port in your config like 8088.
                                • H
                                  hoggboss22
                                  I thought the same thing, i changed from 8080 to 9090 and it gave me the same error. I ran the net stat command to find the port being in used and guess what… there was nothing that is using 8080 or 9090
                                  Active Internet connections (only servers)
                                  Proto Recv-Q Send-Q Local Address           Foreign Address         State
                                  tcp        0      0 0.0.0.0:ssh             0.0.0.0:*               LISTEN
                                  tcp6       0      0 [::]:tproxy             [::]:*                  LISTEN
                                  tcp6       0      0 [::]:ssh                [::]:*                  LISTEN
                                  udp        0      0 0.0.0.0:mdns            0.0.0.0:*
                                  udp        0      0 0.0.0.0:49645           0.0.0.0:*
                                  udp        0      0 0.0.0.0:bootpc          0.0.0.0:*
                                  udp6       0      0 [::]:mdns               [::]:*
                                  udp6       0      0 [::]:44605              [::]:*
                                  raw6       0      0 [::]:ipv6-icmp          [::]:*                  7
                                  Active UNIX domain sockets (only servers)
                                  Proto RefCnt Flags       Type       State         I-Node   Path
                                  unix  2      [ ACC ]     STREAM     LISTENING     7951     /var/run/dbus/system_bus_socket
                                  unix  2      [ ACC ]     STREAM     LISTENING     7954     /var/run/avahi-daemon/socket
                                  unix  2      [ ACC ]     STREAM     LISTENING     7957     /run/thd.socket
                                  unix  2      [ ACC ]     STREAM     LISTENING     10463    @/tmp/.X11-unix/X0
                                  unix  2      [ ACC ]     STREAM     LISTENING     5161     /run/systemd/fsck.progress
                                  unix  2      [ ACC ]     STREAM     LISTENING     10321    /run/user/1000/systemd/private
                                  unix  2      [ ACC ]     STREAM     LISTENING     10326    /run/user/1000/gnupg/S.gpg-agent
                                  unix  2      [ ACC ]     STREAM     LISTENING     10329    /run/user/1000/bus
                                  unix  2      [ ACC ]     STREAM     LISTENING     4967     /run/systemd/private
                                  unix  2      [ ACC ]     STREAM     LISTENING     10331    /run/user/1000/gnupg/S.gpg-agent.browser
                                  unix  2      [ ACC ]     STREAM     LISTENING     10363    /run/user/1000/gnupg/S.gpg-agent.ssh
                                  unix  2      [ ACC ]     STREAM     LISTENING     10365    /run/user/1000/gnupg/S.gpg-agent.extra
                                  unix  2      [ ACC ]     STREAM     LISTENING     8845     /var/run/dhcpcd.sock
                                  unix  2      [ ACC ]     STREAM     LISTENING     5005     /run/systemd/journal/stdout
                                  unix  2      [ ACC ]     STREAM     LISTENING     8847     /var/run/dhcpcd.unpriv.sock
                                  unix  2      [ ACC ]     SEQPACKET  LISTENING     5325     /run/udev/control
                                  unix  2      [ ACC ]     STREAM     LISTENING     10464    /tmp/.X11-unix/X0
                                    12wsx
                                    Hello:) I have similar problem. Magic Mirror installed from image downloaded from this thread. Installed on piZero. Working ok. On screen there was a message to update. I did this and now MM not working. Try config with only clock. Not help.
                                    Full update log.
                                     Starting MagicMirror: v2.1.0
                                    Loading config ...
                                    Starting server op port 8080 ...
                                    Server started ...
                                      code: 'EADDRINUSE',
                                      syscall: 'listen',
                                      address: '::',
                                      port: 8080 }
                                    MagicMirror will not quit, but it might be a good idea to check why this happene        d. Maybe no internet connection?
                                    If you think this really is an issue, please open an issue on GitHub: https://gi        thub.com/MichMich/MagicMirror/issues
                                    (EE)
                                    Fatal server error:
                                    (EE) Server is already active for display 0
                                            If this server is no longer running, remove /tmp/.X0-lock
                                            and start again.
                                    (EE)
                                    (EE)
                                    Please consult the The X.Org Foundation support
                                             at http://wiki.x.org
                                     for help.
                                    (EE)
                                    XIO:  fatal IO error 11 (Resource temporarily unavailable) on X server ":0"
                                          after 7 requests (7 known processed) with 0 events remaining.
                                    pi@raspberrypi:~ $ ^C
                                    pi@raspberrypi:~ $ sudo su
                                    root@raspberrypi:/home/pi# cd ~/MagicMirror && sudo npm install
                                    bash: cd: /root/MagicMirror: No such file or directory
                                    root@raspberrypi:/home/pi# cd MagicMirror
                                    root@raspberrypi:/home/pi/MagicMirror# sudo npm install
                                    npm WARN peerDependencies The peer dependency stylelint@^8.0.0 included from stylelint-config-standard will no
                                    npm WARN peerDependencies longer be automatically installed to fulfill the peerDependency
                                    npm WARN peerDependencies in npm 3+. Your application will need to depend on it explicitly.
                                    npm WARN peerDependencies The peer dependency stylelint@^8.0.0 included from stylelint-config-recommended will no
                                    npm WARN peerDependencies The peer dependency stylelint@^8.0.0 included from grunt-stylelint will no
                                    npm ERR! Linux 4.4.34+
                                    npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "install"
                                    npm ERR! node v4.2.1
                                    npm ERR! npm  v2.14.7
                                    npm ERR! code EPEERINVALID
                                    npm ERR! peerinvalid The package stylelint@7.7.1 does not satisfy its siblings' peerDependencies requirements!
                                    npm ERR! peerinvalid Peer grunt-stylelint@0.9.0 wants stylelint@^8.0.0
                                    npm ERR! peerinvalid Peer stylelint-config-standard@17.0.0 wants stylelint@^8.0.0
                                    npm ERR!     /home/pi/MagicMirror/npm-debug.log
                                    root@raspberrypi:/home/pi/MagicMirror# vendor && npm install
                                    bash: vendor: command not found
                                      A Former User @12wsx
                                      @12wsx
                                      Sometimes, this error seems to happen when MM is terminated abnormally. (I don’t know what is normal termination. :D)
                                      In my case, execution npm for debug or test after first normal pm2 bootup makes this error.(Of course, before npm start dev I stopped pm2 process.)
                                      For the solution, I change port from 8080 to 8081 or from 8081 to 8080(when I meet this problem again). It seems that after some minutes the port is freed automatically(or by execution with port changed.). And fortunately for me, first execution of MM(by pm2 on bootup) is always a success. So… I stop caring about this.
                                        12wsx
                                        my I please someone to make an image of sd card with installed and working MM? i’m trying about week to run MM on piZero and nothing… all the time diffrent errors which i don’t understand.
                                        P 1 Reply Last reply
                                          psteimann @12wsx
                                          @12wsx Change the Port from 8080 to 8099 and then try again…solved a lot of problems for me…
                                          • H
                                            Hawking
                                            After some weeks with the MagicMirror running, my SD card got corrupted and I decided to reinstall the system from scratch. I switched from “Jessie Light” to “Stretch light”, used node 6.11.4 and of course the latest MagicMirror 2.1.3.
                                            I can access the MM from the browser of my laptop, but Midori only shows a white page. Even for a very simple config file:
                                            var config = {
                                                    address: "",
                                                    port: 8080,
                                                    ipWhitelist: ["192.168.2.185", "127.0.0.1", "::ffff:127.0.0.1", "::1"],
                                                    language: "en",
                                                    units: "metric",
                                                            module: "helloworld",
                                                            position: "bottom_bar",
        text: "Hello world!"
                                            The start of MM gives no error
                                            Starting MagicMirror: v2.1.3
                                            Loading config ...
                                            No helper found for module: helloworld.
                                            Server started ...
                                            and if I change from
                                            midori -e Fullscreen -a http://localhost:8080
                                            to
                                            midori -e Fullscreen -a http://www.google.de
                                            I see the google page. So Midori itself and the output on screen seems working as well.
                                            Is anybody having an idea where to search for the error?
                                            Is anybody using MagicMirror 2.1.3 on its Pi Zero?
                                            D 1 Reply Last reply
                                            • 10
                                            • 11
                                            • 6 / 11
