    Background image affected by Margins
    12 Posts 5 Posters 10.9k Views 5 Watching
      A Former User @Wedee
      @Wedee you should change the height and width values also,
      And if you want your img automatically stretching or covering area, use background-size:cover.
        @Wedee and I think padding will not be affected because of region containers are not static positioning; so you can adjust each module location by giving margin to them.
        hmmm. I’m not in front of my machine now, so I cannot give you real code. Sorry.
        • W Offline
          Wedee @Guest
          @Sean Thanks - Ya its not quite working… I am still playing with it. I can get the formatting I want for the content, but the background does not behave how i think it should. Its not a repeating background its something I made at 1920x1080 size. Used to work back several MM versions ago, but it broke and I just turned it off as I could live with the solid black. New application and I really wanted to get a background on it again.
          Keep on playing with it and I might solve it.
          Thanks for the ideas.
            @Wedee how about using some modules for that? There are already many wallpaper or background modules.
            • W Offline
              Wedee @Guest
              @Sean Will have to look at that. Haven’t really looked at all the new modules as everything I needed was all set.
                shashank
                hi, use MMM-Profilepicture module, it will show full screen picture
                module: “MMM-Profilepicture”,
                position: “fullscreen_below”,
                classes: “default everyone”,
                // See below for configurable options
                url: “http://192.168.0.107:8080/MMM-Imagesphotos/photo/1.jpg”
                • W Offline
                  Wedee
                  @Sean @shashank Many thanks for the idea and info regarding the module. While it’s not running as a custom.css it does the job exactly as I required.
                  • pyrosmileyP Offline
                    pyrosmiley
                    In case anyone else is coming into this thread looking for answers, I’ve been stumped on this same problem for awhile and think I got it working (instead of trying to put a picture, I wanted a CSS gradient in the background for various reasons).
                    What I’ve been running into is this: if I put my desired background: info in the body { } portion of the CSS file, it fills up the middle part, but the margins are white. If I put it in the html { } portion, I can make a nice border that fills the margins, but now the inside isn’t covered.
                    After looking through the main.css file (and running enough attempts to lock myself out of the fitbit API), I appear to have gotten it by adding my background: under .region.fullscreen.below. Not knowing how CSS works, I of course only recently figured out that this has to be outside the body{} designation that comes standard in the custom.css file. The code looks kind of like this:
                    body {
                    .region.fullscreen.below {
                      background: linear-gradient(208deg, #235182, #196586);
                    Hope this helps anyone else.
                      prysme01
                      thanks It helps me !
