Including socketNotificationReceived in getDom function
8 Posts 2 Posters 3.2k Views 2 Watching
  • Y Offline
    yours.mukul
    Hi! I’m trying to hack down the google maps modules. I made a node_helper.js to capture the latitude and longitude of desired location, using url.
    the code of main file looks like this
    getDom: function() {
            wrapper.setAttribute("id", "map");
            wrapper.style.height = this.config.height;
            wrapper.style.width = this.config.width;
            var script = document.createElement("script");
            script.type = "text/javascript";
            script.src = "https://maps.googleapis.com/maps/api/js?key=" + this.config.key;
            document.body.appendChild(script);
            script.onload = function () {
                var map = new google.maps.Map(document.getElementById("map"), {
                	zoom: 13,
                	center: {
                		lat: lat,
                		lng: lng
                var trafficLayer = new google.maps.TrafficLayer();
                trafficLayer.setMap(map);
    		return wrapper;
    The latitude and longitude is stored in payload. All I require is ho to use socketNotificationReceived to parse both values as “lat” and “long” in script??
    ? 2 Replies Last reply Oct 30, 2017, 11:46 PM Reply Quote 0
      A Former User @yours.mukul
      @yours.mukul
      getDom() in node_helper.js?
      Y 1 Reply Last reply Oct 31, 2017, 1:58 AM Reply Quote 0
      • Y Offline
        yours.mukul @Guest
        @Sean getDom() in Maps.js
          @yours.mukul
          try this
          in your node_helper.js
          var geo = {
            lat: 12.34567
            lng: 23.45678
          this.sendSocketNotification("REFRESH_GEO", geo)
          in your Main Module
          start: function(){
            this.geo = {
              lat: 0, //default latitude
              lng: 0, //default longitude
          socketNotificationReceived: function(noti, payload) {
            if (noti == "REFRESH_GEO") {
              this.geo.lat = payload.lat
              this.geo.lng = payload.lng
              this.updateDom()
            var lat = this.geo.lat
            var lng = this.geo.lng
            var wrapper = ...
          • Y Offline
            yours.mukul
            @Sean said in Including socketNotificationReceived in getDom function:
            not working, it always shows up 0,0 latitude and longitude…
            ? 1 Reply Last reply Nov 1, 2017, 8:06 AM Reply Quote 0
              @yours.mukul said in Including socketNotificationReceived in getDom function:
              It means, your socketNotificationReceived() in module is not working properly. Try this.
                console.log("NOTIFICATION IS FIRED:", noti)
                  console.log("PAYLOAD IS TREANFERED:", payload)
                  console.log("I'LL UPDATE DOM BY REFRESHED GEO")
                  this.updateDom()
              See how the log says. Check correct Socket Notification is fired with correct payload. If not, check your this.sendSocketNotification() in node_helper.js
              Y 1 Reply Last reply Nov 1, 2017, 10:09 AM Reply Quote 0
              • Y Offline
                yours.mukul @Guest
                @Sean
                node_helper.js
                var NodeHelper = require("node_helper");
                start: function() {
                var geo = {
                  lat: 12.34567,
                  lng: 23.45678
                this.sendSocketNotification("REFRESH_GEO", geo);
                main.js
                /* global Module */
                /* Magic Mirror
                 * Module: MMM-GoogleMapsTraffic
                 * By Victor Mora
                 * MIT Licensed.
                Module.register("MMM-GoogleMapsTraffic", {
                       start: function(){
                  this.geo = {
                    lng: 0 //default longitude
                    this.geo.lat = payload.lat,
                    this.updateDom();
                        var lat = this.geo.lat;
                        var lng = this.geo.lng;
                            	zoom: 13,
                            	center: {
                            		lat: lat,
                            		lng: lng
                		return wrapper;
                ? 1 Reply Last reply Nov 1, 2017, 10:44 AM Reply Quote 0
                  @yours.mukul
                  I think it is not good to put the noti into start() of node_helper.js.
                  Because after finishing module loaded and DOM created, updateDOM() would be working properly, but your code tried too early.
                  As you’ve said, you had your code in node_helper.js to get REAL latitude & longitude, isn’t it? My code was just an example. Send your REAL lat & lng to main module when your node_helper code gathers real target values.
