    Including socketNotificationReceived in getDom function
    8 Posts 2 Posters 3.7k Views 2 Watching
      A Former User @yours.mukul
      @yours.mukul
      try this
      in your node_helper.js
      var geo = {
        lat: 12.34567
        lng: 23.45678
      this.sendSocketNotification("REFRESH_GEO", geo)
      in your Main Module
      start: function(){
        this.geo = {
          lat: 0, //default latitude
          lng: 0, //default longitude
      socketNotificationReceived: function(noti, payload) {
        if (noti == "REFRESH_GEO") {
          this.geo.lat = payload.lat
          this.geo.lng = payload.lng
          this.updateDom()
      getDom: function() {
        var lat = this.geo.lat
        var lng = this.geo.lng
        var wrapper = ...
      • Y Offline
        yours.mukul
        @Sean said in Including socketNotificationReceived in getDom function:
        not working, it always shows up 0,0 latitude and longitude…
          @yours.mukul said in Including socketNotificationReceived in getDom function:
          It means, your socketNotificationReceived() in module is not working properly. Try this.
            console.log("NOTIFICATION IS FIRED:", noti)
              console.log("PAYLOAD IS TREANFERED:", payload)
              console.log("I'LL UPDATE DOM BY REFRESHED GEO")
              this.updateDom()
          See how the log says. Check correct Socket Notification is fired with correct payload. If not, check your this.sendSocketNotification() in node_helper.js
          • Y Offline
            yours.mukul @Guest
            @Sean
            node_helper.js
            var NodeHelper = require("node_helper");
            start: function() {
            var geo = {
              lat: 12.34567,
              lng: 23.45678
            this.sendSocketNotification("REFRESH_GEO", geo);
            main.js
            /* global Module */
            /* Magic Mirror
             * Module: MMM-GoogleMapsTraffic
             * By Victor Mora
             * MIT Licensed.
            Module.register("MMM-GoogleMapsTraffic", {
                   start: function(){
              this.geo = {
                lng: 0 //default longitude
                this.geo.lat = payload.lat,
                this.updateDom();
                    var lat = this.geo.lat;
                    var lng = this.geo.lng;
                    wrapper.setAttribute("id", "map");
                    wrapper.style.height = this.config.height;
                    wrapper.style.width = this.config.width;
                    var script = document.createElement("script");
                    script.type = "text/javascript";
                    script.src = "https://maps.googleapis.com/maps/api/js?key=" + this.config.key;
                    document.body.appendChild(script);
                    script.onload = function () {
                        var map = new google.maps.Map(document.getElementById("map"), {
                        	zoom: 13,
                        	center: {
                        		lat: lat,
                        		lng: lng
                        var trafficLayer = new google.maps.TrafficLayer();
                        trafficLayer.setMap(map);
            		return wrapper;
              @yours.mukul
              I think it is not good to put the noti into start() of node_helper.js.
              Because after finishing module loaded and DOM created, updateDOM() would be working properly, but your code tried too early.
              As you’ve said, you had your code in node_helper.js to get REAL latitude & longitude, isn’t it? My code was just an example. Send your REAL lat & lng to main module when your node_helper code gathers real target values.
