Calendar won't finish loading
I have put in a url (webcal://calendar.google.com/…/basic.ics)
And the calendar will not load.
I am running on a raspberry pi b+, so maybe it is because node is outdated?
Any ideas? -
@johnpturner8 Have you tried to access the ics file straight from the pi (through a browser maybe)? Would be the first thing I would test. To see if it can even reach it at all.
@EoF It wouldn’t connect to the webcal:// address, but when I replaced it with http:// it downloaded the file. I tried replacing it in the config files but it still won’t load
The default calendar didn’t load either, so it may not be the url.
Please note that Raspberry Pi 1 (any version) is not supported. The software on them is just too damn old. You might be able to run MM¹ on it.
@KirAsh4 I’ve gotten it running in kiosk mode, but the calendar might not work on it. If it doesn’t I’ll just get rid of it.
