    MMM-PrayerTime
    Scheduled Pinned Locked Moved Education
    55 Posts 14 Posters 54.9k Views 14 Watching
    • slametpsS Offline
      slametps @AAPS
      @AAPS you can set config playAdzan as following to tell module NOT to play adzan:
      playAdzan: [],
      regards,
      Slamet PS
        AAPS @slametps
        @slametps Thanks! This’ll work much better than the calendar method.
        • Z Offline
          zzaidi148 @slametps
          @slametps Thank you for making this module. I just wanted to ask you why my config wouldn’t validate. I am in central north america. This is my config:
          			module: 'MMM-PrayerTime',
          			position: 'bottom_right',
          			apiVersion: '1.0'
          			lat: 38.033184,
          			lon: -86.625225,
          			timezone: true,
          			method: 5,
          			playAdzan: ['fajr', 'dhuhr', 'asr', 'maghrib', 'isha'],
          			notDisplayed: ['midnight', 'sunset'],
          			useUpdateInterval: true,
          			updateInterval: 86400 * 1000,
          			animationSpeed: 2.5 * 1000,
          			language: config.language,
          			showAdzanAlert: true,
          			alertTimer: 15000
          • Y Offline
            yawns Moderator @zzaidi148
            @zzaidi148
            There is a comma missing after apiVersion: '1.0'
            Z 1 Reply Last reply Reply Quote 0
            • Z Offline
              zzaidi148 @yawns
              @yawns tried that but didn’t work. I think it has to be something with the timezone.
              slametpsS 1 Reply Last reply Reply Quote 0
              • slametpsS Offline
                slametps @zzaidi148
                @zzaidi148 said in MMM-PrayerTime:
                There is a missing comma after apiVersion: '1.0'. What does not work? What you get on your mirror? Or in pm/mm log?
                regards,
                Slamet PS
                • N Offline
                  noorm91
                  I am having trouble with my module…
                                                  apiVersion: '1.0',
                                                  lat: 55.841727,
                                                  lon: 13.303381,
                                                  timezone: Europe/Stockholm,
                                                  method: 3,
                                                  alertTimer: 15000
                  can you see anything wrong?
                  • slametpsS Offline
                    slametps @noorm91
                    @noorm91 said in MMM-PrayerTime:
                                                   apiVersion: '1.0',
                                                   lat: 55.841727,
                                                   lon: 13.303381,
                                                   method: 3,
                                                   alertTimer: 15000
                    It should be timezone: 'Europe/Stockholm'.
                    regards,
                    Slamet PS
                    • Z Offline
                      zzaidi148 @slametps
                      @slametps The mirror cannot validate the config.
                      • Z Offline
                        zzaidi148 @zzaidi148
                        @slametps It cannot read propert ‘language’
                        • N Offline
                          noorm91
                                              position: 'top_right',
                                                      apiVersion: '1.0',
                                                      lat: 55.841727,
                                                      lon: 13.303381,
                                                      timezone: 'Europe/Stockholm',
                                                      method: 3,
                                                      alertTimer: 15000
                          Salam, changed it but still not working :( lon/lat: is ok? how about language: ?
                          Actually this is my first module I’m trying to get working, pretty new to MM2 so maybe I need to change somewhere else too.
                          The module is under here;
                          pi@raspberrypi:~/MagicMirror/modules $ ls
                          default MMM-PrayerTime node_modules README.md
                          pi@raspberrypi:~/MagicMirror/modules/MMM-PrayerTime $ ls
                          LICENSE MMM-PrayerTime.css MMM-PrayerTime.js node_helper.js README.md res screenshot2.jpg screenshot-alert.png screenshot.png translations
                          • slametpsS Offline
                            slametps @noorm91
                                                        apiVersion: '1.0',
                                                        lat: 55.841727,
                                                        lon: 13.303381,
                                                        method: 3,
                                                        alertTimer: 15000
                            You may simply remove language: config.language line, and see if this work. It tells MMM-PrayerTime module to use MM global language config. If not work, please use 'en' for language entry.
                            regards,
                            Slamet PS
                            • N Offline
                              noorm91
                              Alhamdulillah almost there, the module shows up in top_right with this conf, but it just says " Loading … " any known reason?
                                                          apiVersion: '1.0',
                                                          lat: 55.841727,
                                                          lon: 13.303381,
                                                          timezone: "Europe/Stockholm",
                                                          method: 3,
                                                          language: 'en',
                                                          alertTimer: 15000
                              • slametpsS Offline
                                slametps @noorm91
                                @noorm91 can you post the pm2/mm log?
                                regards,
                                Slamet PS
                                • Z Offline
                                  zzaidi148 @slametps
                                  @slametps Alhamdulillah I got it work by taking out the language line. It works well now. I was wondering if there was any way I could take out the Imsak times from the module and to have the times be in a 12 hour format. Also, how do I make sure that it plays the athan? Thanks for all the help!
                                  • slametpsS Offline
                                    slametps @zzaidi148
                                    You can remove Imsak from the schedule by adding config notDisplayed: ['midnight', 'sunset', 'imsak']. Currently, support 24-hour format only.
                                    Your MM has speaker? If yes, you can check type following command in console:
                                    /usr/bin/omxplayer -o hdmi modules/MMM-PrayerTime/res/adzan.mp3
                                    It will play adzan.mp3.
                                    regards,
                                    Slamet PS
                                    • N Offline
                                      noorm91
                                      I will try get the log when I’m home, just a simple question, does this work with Midori browser, because that is the one I’m using on Rpi 1 model b…I entered my Rpi IP address in chrome from my computer and then I saw the module perfectly.
                                      slametpsS A 2 Replies Last reply Reply Quote 0
                                      • slametpsS Offline
                                        slametps @noorm91
                                        Sorry, I haven’t test it on midori browser.
                                        regards,
                                        Slamet PS
                                        • Z Offline
                                          zzaidi148
                                          Is it possible to use another api service like islamic finder or salah times api so it would allow for 12-hour format? Thank You
                                          • slametpsS Offline
                                            slametps @zzaidi148
                                            You should modify the module according to each API provider data. Why should be 12-hour format?
                                            regards,
                                            Slamet PS
