    Question about calendar
    9 Posts 5 Posters 38.9k Views 4 Watching
    • KirAsh4K Offline
      KirAsh4 Moderator
      In its simplest form:
                      url: 'https://calendar.google.com/calendar/ical/FILL_IN_YOUR_INFO'
      To get your Google Calendar link, look in your calendar settings. You want to use the private ICAL address. Note that it will only display what is on the default calendar. The way Google split Birthdays from the default calendar makes it so those don’t show up (and they aren’t providing an ICAL link to the Birthdays one either - this is a major complaint from many.) And if you have multiple calendars created, you need to include each one separately.
      VanzoV 1 Reply Last reply Reply Quote 0
        patm189
        Hi @KirAsh4 , thanks for the info! I am running into an issue with combining multiple calendars.
        I have successfully added my Google calendar by replacing calendarlabs default with my personal ical address. However, I still want to US Holidays to show. I am only seeing my personal google calendar showing with the following code. I even tried rearranging the order, but it doesn’t seem to want to show Holidays. Memorial Day isn’t showing up, but my personal meeting much further in the future are showing. Are you putting both calendars into the config.js and the calendar.js file?
        				symbol:"calendar",
        				url:"http://www.calendarlabs.com/templates/ical/US-Holidays.ics",
        				symbol: "calendar",
        				url: "https://calendar.google.com/calendar/ical/MY_INFO.ics",
        1 Reply Last reply Reply Quote -3
        • KirAsh4K Offline
          KirAsh4 Moderator
          @patm189, my config is in the post above yours. I actually have 3 calendars listed that way.
          • VanzoV Offline
            Vanzo @KirAsh4
            Thank you @KirAsh4. You’ve been very kind ;)
            • N Offline
              NJRonbo
              I have successfully added Google Calendar to my Mirror, however on my listings all I get is BUSY 3 DAYS; BUSY 3 MONTHS.
              No specific details on events.
              I did go into Calendar settings and make my calendar public.
              Anything I might be doing wrong?
              • foxF Offline
                fox
                Also a question.
                I have two entries at one day.
                Only one is displayed…
                No one is private
                Any ideas ?
                Issues With MMM-WatchDog known?
                https://forum.magicmirror.builders/post/29827
                Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
