    MMM-ModuleScheduler - issues
    2 Posts 2 Posters 2.3k Views 2 Watching
      Brandlin
      Hi
      I am trying to use the MMM-ModuleScheduler module to show sports league tables only during the relevant season. eg only show the Formula1 standings between March and November and football league table only between August and May. Each of the modules is in the same screen position and uses MMM-Carousel to rotate between them.
      My config is
                              module: 'MMM-ModuleScheduler'
      and then for the MMM-Formula1 module
                              module: 'MMM-Formula1',
                              position: 'top_left',
                              classes: 'scheduler',
                                      type: 'driver',
                                      maxRows: "5",
                                      calendar: "true",
                                      fade: "true",
                                      module_schedule: {from: "* * 1 3 *", to: "* * 30 11 *" }
      No matter what I have tried, the MMM-ModuleScheduler causes the mirror display to be blank.
      If I comment out the first section of code above then the mirror runs fine. This seems to suggest that the issue is in the module: statement?
      What am I doing wrong?
      • yawnsY
        yawns Moderator
        Did you install the MMM-ModuleScheduler after git cloning it? Do you see any error messages in the log of magic mirror
        • if run with pm2: type pm2 logs mm in terminal
        • if run manually: look at the terminal for any error messages
        • in browser hit F12 and look for console -> errors
