    MMM-FHEM no Fhem statusdisplay
    11 Posts 5 Posters 9.7k Views 5 Watching
    • N
      Nonamexp
      Hello, you have deactivate The Passwort in fhem?!
      • strawberry 3.141S
        strawberry 3.141 Project Sponsor Module Developer @Woody
        @Woody I don’t have experience with this specific module, but I can tell you the way you defined the boolean https was always true.
        In Javascript a string is always true no matter what the content is "hello" -> true, "true" -> true, "false" -> true.
        If you remove the quotes and try again https: false, then you will really use http instead of https.
        • W
          Woody
          Thanks Folks,
          it seem I was completely stumped. Sometimes I overlook the simplest things.
          The password was the problem but, at least I think this is not a good solution to access Fhem without authorization. Anyway, problem solved - thanks a lot.
          Rgs. Woody
          D 1 Reply Last reply
            dominic @Woody
            @Woody said in MMM-FHEM no Fhem statusdisplay:
            Thanks Folks,
            Rgs. Woody
            Hi Woody,
            how can i deactivate the passwort? I think my problem is the same.
            • W
              Woody
              in fhem you have to disable “basicAuth” in fhem.cfg like this…
              #attr allowed_WEB basicAuth shjedIOhbn6BHFJjGH
              D 2 Replies Last reply
                dominic @Woody
                Hi Woody, thanky you for your answer. Can you explain it?
                I have defined WEB and than ? Sorry i am very new in FHEM what means " shjedIOhbn6BHFJjGH"?
                  dominic @Woody
                  @Woody
                  So i now there is this entrie in the config.cfg “define allowed_WEB allowed
                  #attr allowed_WEB basicAuth xxxxxxxxxxxxxxx
                  #attr allowed_WEB validFor WEB”
                  and my config.js looks like this
                      module: 'MMM-FHEM',
                      position: 'top_right',
                        host: 'localhost',
                        port: '8083',
                        https: false,
                  	        devices: [
                                    { deviceName: 'ESPEasy_ESP_Test_DHT',
                                      deviceReadings: [
                                                        { name: 'Temperatur', icon: 'wi wi-thermometer', suffix: '°' },
                                                        { name: 'Humidity', icon: 'wi wi-humidity', suffix: '%' },
                                    { deviceName: '',
                                      deviceReadings: [
                                                        { name: 'Humidity', icon: 'fa fa-battery-half', suffix: '' },
                  And this is in FHEM…
                  where is the mistake?
                  • W
                    Woody
                    @dominic said in MMM-FHEM no Fhem statusdisplay:
                    shjedIOhbn6BHFJjGH is your base64 encoded string of user:password in your fhem.cfg.
                    In your forelast post it seems to be out commented with a # as i recommended in my last post. For me this means that you’ve no authentication in place and your original problem seems not to be an authorization issue.
                      dominic @Woody
                      @Woody Thank you, yes i think my originlproblem is not the authorization.
                      Do you have any idea., what it could be ?
                      • H
                        Hotstepper
                        it seems to be a problem with fhem’s security mechanism “csrfToken”.
                        You can define a new Web in fhem with a different port and set this up as follws:
                        fhem.cfg:
                        define MagicM FHEMWEB 8086 global
                        attr MagicM allowfrom 192.168.1.14
                        attr MagicM csrfToken none
                        Explanation:
                        • This define’s a new listening port at your fhem server on port 8086
                        • The only allowed ip is 192.168.1.14 This is the ip of your MagicMirror Device. Choose your ip.
                        • Disable the use of csrfToken. https://fhem.de/commandref.html or https://wiki.fhem.de/wiki/CsrfToken-HowTo
                        After fhem restart your readings will be shown at your MagicMirror.
                        Hope it helps.
                        Greetz, Hotstepper.
