no helpers found for currentweather and weather forecast
These two modules are not working for me. I got “no helpers found” error.
Here is the code{ module: "currentweather", position: "top_right", config: { location: "Trabzon", locationID: "738648", //ID from http://www.openweathermap.org/help/city_list.txt appid: "api.openweathermap.org/data/2.5/weather?id=738648" } }, { module: "weatherforecast", position: "bottom_right", header: "Weather Forecast", config: { location: "Trabzon", locationID: "738648", //ID from http://www.openweathermap.org/help/city_list.txt appid: "api.openweathermap.org/data/2.5/weather?id=738648" } }, -
@okg21
“no helper modules found” is no error, not even a warning. Some modules do not need anode_helper.jsfileYour major problem is your appid. The appid can be found when logging in to openweathermap.org. It looks like this:
@yawns Thanks a lot.
