Showing temperature from php file
6 Posts 3 Posters 3.5k Views 4 Watching
  • 1 Offline
    12wsx
    May I please someone to write simple module to show temperature from this link
    http://solartemp.no-ip.org:3000/lcdfeed.php?key=AAaaAAaaAA&group=e28ca223
    it is simple text. or maybe ther is a module which can simply adapt. I tried use MMM-Rest module but it is not starting “module loading” I’m very newbie in magic mirror and not a programmer so i can’t do it by my self.
    Regards
    Daniel
    • Y Offline
      yawns Moderator
      https://forum.magicmirror.builders/topic/5743/mmm-solartemp
      like this? ;)
      Configuration like this:
      			module: "MMM-Solartemp",
      			position: "bottom_right",
      			header: "Solartemp",
      				baseURL: "http://solartemp.no-ip.org:3000/lcdfeed.php",
      				key: "AAaaAAaaAA",
      				group: "e28ca223"
      Could you please explain a bit more which sensors this module is using? Maybe others could use it as well.
      • 1 Offline
        12wsx
        @12wsx said in Showing temperature from php file:
        Thank You Very Very much! it works great!
        This project is Nettemp- smart home project from poland.
        A lots of stuff- ds18b20, bme280, Air quality PMSx003, DIY Meteo by@pimowo- lightning sensor AS3935. Power, water, electricity reading and many many others.
        I Have only one question- how to change font ?
        Y 1 Reply Last reply Dec 18, 2017, 2:49 PM Reply Quote 0
        • Y Offline
          yawns Moderator @12wsx
          @12wsx
          Either you manipulate MMM-Solartemp.css in module folder ~/MagicMirror/modules/MMM-Solartemp or you modify custom.css in ~/MagicMirror/css
           .figures {
          	 font-family: "Times New Roman" !important;
          If you use the second option you are not running into problems if there is an update to the module.
          • O Offline
            onetwankyfive
            this looks pretty cool
            http://techfreak.pl/nettemp/
            • 1 Offline
              12wsx
              next question.
              is it Possible to use this module two times in one MM?
              I want to use it on left for home sensor and on right for own meteo station and air quality?
