Possible Issue: MMM-GoogleAssistant with recent Google Assistant SDK update
4 Posts 3 Posters 4.7k Views 3 Watching
  • T Offline
    teamreflect
    Tried installing the MMM-GoogleAssistant today and tried to make it with the work with new google assistant sdk update… I ran in to this following error code:
    File "assistant.py", line 133, in
      main()
    File "assistant.py", line 130, in main
      init_googleAssistant()
    File "assistant.py", line 124, in init_googleAssistant
      with Assistant(credentials) as assistant:
    TypeError: __init__() missing 1 required positional argument: 'device_model_id'
    hello from python!!
    any ideas on what is causing the problem?
      Raddy
      I’m having the same issue. I followed the instructions listed link text here and can get the sample assistant script to run from Google, but when I run the assistant.py script, I get the same error as above.
        Raddy
        Solved it!
        The SDK update changed the assistant initiation call. You registered a device_model_id (“Raddys-magic-mirror-device-id” for example) in the original instructions, so you have to add that to the assistant.py file. (Here are instructions on manually registering a device and creating a device instance–I don’t know if an instance is required for this to work, but it’s part of what I did trying to solve this).
        Open the assistant.py code and scroll down to line 124. The current call is this:
        In the updated method found on Google’s dev site, it should read:
        with Assistant(credentials, device_model_id) as assistant:
        Where you replace device_model_id with whatever you registered before.
        with Assistant(credentials, "Raddys-magic-mirror-device-id") as assistant:
        Run it and it should work!
        G 1 Reply Last reply Feb 21, 2018, 1:33 PM Reply Quote 0
        • G Offline
          gauravsacc Module Developer @Raddy
          @Raddy said in Possible Issue: MMM-GoogleAssistant with recent Google Assistant SDK update:
          d method f
          just an update. I’ve updated the MMM-GoogleAssistant module to work with the new SDK :)
