    Npm start issues
    12 Posts 2 Posters 10.2k Views 1 Watching
      Coltjb45
      magicmirror@2.1.3 start /home/pi/MagicMirror
      sh run-start.sh
      run-start.sh: 4: run-start.sh: electron: not found
      npm ERR! magicmirror@2.1.3 start: sh run-start.sh
      npm ERR! Exit status 127
      npm ERR!
      npm ERR! Failed at the magicmirror@2.1.3 start script.
      npm ERR! This is most likely a problem with the magicmirror package,
      npm ERR! not with npm itself.
      npm ERR! sh run-start.sh
      npm ERR! You can get their info via:
      npm ERR! npm owner ls magicmirror
      npm ERR! System Linux 4.9.59-v7+
      npm ERR! command “/usr/bin/nodejs” “/usr/bin/npm” “start”
      npm ERR! cwd /home/pi/MagicMirror
      npm ERR! node -v v4.8.2
      npm ERR! npm -v 1.4.21
      npm ERR! code ELIFECYCLE
      npm WARN This failure might be due to the use of legacy binary “node”
      npm WARN For further explanations, please read
      /usr/share/doc/nodejs/README.Debian
      npm ERR!
      npm ERR! Additional logging details can be found in:
      npm ERR! /home/pi/MagicMirror/npm-debug.log
      npm ERR! not ok code 0
      • cruunnerrC Offline
        cruunnerr
        did you run npm install first? or did u use the automatic installer? Looks like there is no electron installed.
        maybe try to execute “DISPLAY=:0 nohup npm start &”
        But i need to say that i am no developer or programer or something like that. Just started to try understanding the whole stuff ^^
        So keep that i mind and before u crash something maybe u should wait for someone who got more ideas.
        for so long keep reading: https://www.google.de/search?client=safari&rls=en&q=run-start.sh:+4:+run-start.sh:+electron:+not+found&ie=UTF-8&oe=UTF-8&gfe_rd=cr&dcr=0&ei=Q9JDWuagJ6zBXqmvrKAI
          Coltjb45
          I’m just starting out too, that’s why I’m having problems. Lol
            cruunnerr
            hmm. which os did u use? is it a fresh install?
            I’m using stretch lite, but that needs more steps to install the MM.
            So i recommend to use a desktop version (with pixel) for the first.
            If u did, i would use this guide: https://forum.magicmirror.builders/topic/236/complete-setup-tutorial
            Or, if u would like to use a lite OS Version i would use this: https://github.com/MichMich/MagicMirror/wiki/Jessie-Lite-Installation-Guide
            Last one worked fine for me. It takes about 30-60 Minutes all in all to set up the Magic Mirror when i did it first time. Important is to read carefully and take the time u need for it ;)
              Coltjb45
              I used automatic installer. And the OS was the lite system that came with my raspberry
                Coltjb45
                I tried your first suggestion and this is what happened.
                pi@raspberrypi:~/MagicMirror $ DISPLAY=:0 nohup npm start &
                [1] 1854
                pi@raspberrypi:~/MagicMirror $ #nohup: ignoring input and appending output to 'nohup.out
                  cruunnerr
                  that should be the reason, why u are running in trouble. With the lite version there are missing some packages, which u have to install manually.
                  i would delete the MagicMirror folder with “rmdir MagicMirror” and try to set it up again with using the second link i posted above.
                  Even better if u install a whole new OS on your SD-Card, 'cause i don’t know what stuff is installed there.
                    Coltjb45
                    It said failed to remove magic mirror
                      cruunnerr
                      try
                      rmdir /home/pi/MagicMirror
                      or maybe
                      sudo rmdir /home/pi/MagicMirror
                        Coltjb45
                        both didn’t work
