Blank mirror?
Hi! A new setup on a ubuntu server, trying to use server only.
This is what i get:
node serveronly:
lange@tower:~/MagicMirror$ node serveronly/ Starting MagicMirror: v2.1.3 Loading config ... Loading module helpers ... No helper found for module: alert. Initializing new module helper ... Module helper loaded: updatenotification No helper found for module: clock. Initializing new module helper ... Module helper loaded: calendar No helper found for module: compliments. No helper found for module: currentweather. No helper found for module: weatherforecast. Initializing new module helper ... Module helper loaded: newsfeed All module helpers loaded. Starting server on port 8080 ... Server started ... Connecting socket for: updatenotification Connecting socket for: calendar Starting node helper for: calendar Connecting socket for: newsfeed Starting module: newsfeed Sockets connected & modules started ... Ready to go! Please point your browser to: http://192.168.1.123:8080
This is what i get when using sh run-start.sh
lange@tower:~/MagicMirror$ sh run-start.sh /usr/local/lib/node_modules/electron/dist/electron: error while loading shared libraries: libgtk-x11-2.0.so.0: cannot open shared object file: No such file or directory
Help please :)
@Lange said in Blank mirror?:
what happened when you tried to access that in your browser?
A Black blank page. Like moduls are not loading
npm install --unsafe-perm fixed the problem for me.
Hurrah! You saved my sanity! Finally, after several days of repeated reinstalls and fiddling, it lives!
@Esinem said in Blank mirror?:
Ive seen many with the problem, but no one has posted the solution. There for, always visit your old posts :D
