Updating to v2.2.0...
11 Posts 3 Posters 5.6k Views 2 Watching
    stephenmelody
    So… I think I did the right thing, but how do I know when it’s updated?
    alt text
    B 1 Reply Last reply Jan 2, 2018, 7:24 PM Reply Quote 0
      bhepler Module Developer @stephenmelody
      @stephenmelody Empty responses are good. That usually means no problems. Once you have your command line back, you’re free to proceed.
        stephenmelody
        it came back within a second… when you say proceed… what’s next?
        B 1 Reply Last reply Jan 2, 2018, 7:36 PM Reply Quote 0
          @stephenmelody Next step is to run your mirror and make sure nothing has changed.
            stephenmelody
            nothing has changed, I’m still 86 commits behind on the master branch.
              stephenmelody
              Am I doing it in the right folder? Is the command correct? I’m getting the same response no matter what folder i’m in within the MM install
                stephenmelody
                Can anyone help? I get the same message no matter what I try to do.
                  mochman Module Developer
                  Just trying to cover all the bases here, but are you on the master branch? You can run git branch to see. It should say something like:
                  pi@Magic-Mirror:~/ $ cd MagicMirror
                  pi@Magic-Mirror:~/MagicMirror $ git branch
                  * master
                  The asterisk denotes which branch is your current one.
                  If for some reason you’re not on the master branch use git checkout master to switch back to the master branch.
                  Then try running git pull and see if anything happens. Hopefully you get a list of files that have been changed. If not, and you don’t see an error messages try git pull -v to see what errors (if any) you are getting.
                  Hopefully that all works out, then you can just run npm install and you should be all set.
                  Good luck.
                    stephenmelody
                    Thanks @mochman
                    This is what I’m getting now… any clues??
                    ![alt text](0_1515338090347_dc675bca-05e1-45c1-a9d0-3fd3577e4fa6-image.png image url)
                      okay, try running
                      rm -f ~/MagicMirror/.git/index.lock
                      then try git pull again. Hopefully you’ll see more than:
                      Updating b799609..20823bf
