    Calendar module won't show all events
    7 Posts 5 Posters 4.3k Views 5 Watching
    • G
      gama
      The default calendar module connects to my iCloud calendars fine, but won’t show all events. I switched to MMM-CalendarExt and it shows perfectly.
      After the recent update of MagicMirror, MMM-CalendarExt won’t display on screen at all. I just need one of them to work properly. Any ideas?
      H 1 Reply Last reply
      • H
        Hein-Jan @gama
        @gama
        Look into issue:
        https://forum.magicmirror.builders/topic/5071/mmm-calendarext-cant-get-the-calendar-to-show
        It is a problem of Electron that has been downgraded.
        The default calendar module has had some issues removed in the update, maybe it is now okay for you.
        • G
          gama
          This is what I found out.
          Here’s the code at that location:
          addCalendars: async function() {
              var self = this
              for (var c in this.CurrentConfigs.calendars) {
                self.addCalendar(self.CurrentConfigs.getCalConfig(c))
                await sleep(1000)
          Could it be that the error is within the core programming of the module?
          • N
            ninjabreadman
            I’ve had the same problem since upgrading to MagicMirror 2.2.0.
            It seems that Node.js is upset that MMM-CalendarExt uses an async function at MMM-CalendarExt.js:182. From what I can tell, Node.js didn’t support async until 7.4, and I’m (apparently) running 6.12.2 (via node -v). However, until I upgraded MagicMirror this weekend, MMM-CalendarExt was working fine.
            I just edited run-start.sh:4 to the following, and just got MMM-CalendarExt working again:
            electron --js-flags="--harmony-async-await" js/electron.js $1
            Can someone explain why upgrading to MagicMirror 2.2.0 would’ve rolled back the Node.js support for async?
            G D ? 3 Replies Last reply
            • G
              gama @ninjabreadman
              @ninjabreadman
              Nice. Thanks for the workaround! It’s working now.
                Daveladd @ninjabreadman
                @ninjabreadman
                Slick fix, Well done. Think this should get pushed to the master branch? Does not seem it will get in the way of other functionality/stability since we can still use the lower electron version but obviously the workaround means updates involve stashing changes and such.
                  A Former User @ninjabreadman
                  @ninjabreadman said in Calendar module won’t show all events:
                  electron --js-flags=“–harmony-async-await” js/electron.js $1
                  It’s a great fix for this issue. Anyway, I’m almost finishing my vacation and my current business a few days. I should have to join the summit for business in mid of January in Seoul and Paris. After that, I will release fix of this issue.
