Error: Module version mismatch. Expected 50, got 54
4 Posts 3 Posters 2.4k Views 3 Watching
    MadScientist
    I have just updated updated my MagicMirror installation to the current 2.2.0 but now I only get a blank screen.
    npm start
    shows the following output.
    > magicmirror@2.2.2 start /home/pi/MagicMirror
    > sh run-start.sh
    Starting MagicMirror: v2.2.2
    Loading config ...
    Loading module helpers ...
    WARNING! Could not load config file. Starting with default configuration. Error found: Error: Module version mismatch. Expected 50, got 54.
    App threw an error during load
        at Error (native)
        at process.module.(anonymous function) [as dlopen] (ELECTRON_ASAR.js:173:20)
        at Object.Module._extensions..node (module.js:583:18)
        at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR.js:173:20)
        at Module.load (module.js:473:32)
        at tryModuleLoad (module.js:432:12)
        at Function.Module._load (module.js:424:3)
        at Module.require (module.js:483:17)
        at require (internal/module.js:20:19)
        at bindings (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/bindings/bindings.js:81:44)
        at Error (native)
    Launching application.
    ^CShutting down server...
    I don’t really know what that version mismatch means. I haven’t changed anything else to my set-up but just updated from the previous release to the current one. Any help before I wipe everything and start all over new?
      paul.calladine
      I had this and managed to correct it by following the steps listed here at the end of the readme. Worked for me but not sure if it’ll work for you so i’d recommend backing up first.
      https://github.com/ryck/MMM-DHT-Sensor
      cd MMM-DHT-Sensor
      npm install electron-rebuild
      ./node_modules/.bin/electron-rebuild
      But substituting MMM-DHT-Sensor for your module above ‘MMM-PIR-Sensor’
        MadScientist
        Thanks for the very quick reply. I am currently backing up my MM install and give it a try.
        Edit: For a test I just did a
        npm install
        and checked if the mirror starts up. Which it did. Thanks so much for your help!
          CharonBeber
          npm install worked for me as well, somehow npm rebuild didnt do this job.
