Access the default values in outside functions
I’m having troubles accessing my default values in my hello function, in my start function the values exist but in hello they are undefined and unreadable, code is below:
Module.register("jarvis", { // Module defaults defaults: { assistantName: "jarvis", assistantVoice: "UK English Male" }, // Required Scripts getScripts: function() { return ["annyang.js", "http://code.responsivevoice.org/responsivevoice.js"]; }, hello: function(name) { if(name) name = name.trim().toLowerCase(); Log.info(name) Log.info(this.config.assistantName) if(name && (name == this.config.assistantName)) responsiveVoice.speak("Hello George"); else { responsiveVoice.speak("Hello"); } }, start: function() { Log.info("Starting module: " + this.name); annyang.debug(); if (annyang) { // Let's define a command. var commands = { 'hello (*name)': this.hello }; // Add our commands to annyang annyang.addCommands(commands); // Start listening. annyang.start(); } Log.info(this.config.assistantVoice) Log.info(this.config.assistantName) // Setting voice default responsiveVoice.setDefaultVoice(this.config.assistantVoice); } });Please help, thank you!
That’s because “this” is no longer referring to your instance. It’s a common javascript pitfall. Check out:
http://javascriptplayground.com/blog/2012/04/javascript-variable-scope-this/ -
@MichMich Oh okay, thanks for the help!
