    Access the default values in outside functions
    Scheduled Pinned Locked Moved Solved Development
    3 Posts 2 Posters 2.1k Views 1 Watching
    • G Offline
      gndimitro
      I’m having troubles accessing my default values in my hello function, in my start function the values exist but in hello they are undefined and unreadable, code is below:
      Module.register("jarvis", {
      // Module defaults
        defaults: {
          assistantName: "jarvis",
          assistantVoice: "UK English Male"
        // Required Scripts
        getScripts: function() {
      	return ["annyang.js",
              "http://code.responsivevoice.org/responsivevoice.js"];
      hello: function(name) {
          if(name)
            name = name.trim().toLowerCase();
      Log.info(name)
      Log.info(this.config.assistantName)
      if(name && (name == this.config.assistantName))
        responsiveVoice.speak("Hello George");
      else {
        responsiveVoice.speak("Hello");
        start: function() {
        annyang.debug();
          if (annyang) {
            // Let's define a command.
            var commands = {
              'hello (*name)': this.hello
            // Add our commands to annyang
            annyang.addCommands(commands);
            // Start listening.
            annyang.start();
      Log.info(this.config.assistantVoice)
      // Setting voice default
      responsiveVoice.setDefaultVoice(this.config.assistantVoice);
      Please help, thank you!
      • MichMichM Offline
        MichMich Admin
        That’s because “this” is no longer referring to your instance. It’s a common javascript pitfall. Check out:
        http://javascriptplayground.com/blog/2012/04/javascript-variable-scope-this/
        • G Offline
          gndimitro @MichMich
          @MichMich Oh okay, thanks for the help!
