Resolution has changed...how do I get it back?
3 Posts 2 Posters 1.8k Views 2 Watching
    budwha
    I am very new and still learning…yesterday I entered display_rotate=1 in config,txt file to see if I could rotate the display(just to see if I could)…it worked so then I deleted it and shutdown the pi. Today when I boot the pi its resolution is changed and the fonts are all too big in the pi desktop and the Magic Mirror. All I did was add rotate and remove it. Here is my config.txt
    #hdmi_mode=3
    # uncomment to force a HDMI mode rather than DVI. This can make audio work in
    # DMT (computer monitor) modes
    #hdmi_drive=2
    # uncomment to increase signal to HDMI, if you have interference, blanking, or
    # no display
    #config_hdmi_boost=4
    # uncomment for composite PAL
    #sdtv_mode=2
    #uncomment to overclock the arm. 700 MHz is the default.
    #arm_freq=800
    # Uncomment some or all of these to enable the optional hardware interfaces
    #dtparam=i2c_arm=on
    #dtparam=i2s=on
    #dtparam=spi=on
    # Uncomment this to enable the lirc-rpi module
    #dtoverlay=lirc-rpi
    # Additional overlays and parameters are documented /boot/overlays/README
    # Enable audio (loads snd_bcm2835)
    dtparam=audio=on
    # NOOBS Auto-generated Settings:
    #hdmi_force_hotplug=1
    • Y Offline
      yawns Moderator
      Is this the entire config.txt? I can’t see your rotate entry :)
      In pi desktop select start menu -> Preferences -> Raspberry Pi Configuration and set your resolution again.
      Like here: https://raspberrypi.stackexchange.com/a/66322
      B 1 Reply Last reply Feb 15, 2018, 3:07 PM Reply Quote 0
        budwha @yawns
        @yawns Thanks…I tried changing the resolution but it didn’t take…tried it a second time and its ok now.
