    current Weather form .json file
    4 Posts 2 Posters 2.0k Views 2 Watching
    • G Offline
      Gasoman
      How can I get the temperature and humidity form a .json file. The file is under the adress http://myIP/weather.json has this data:
      “os selected”: {
      “inside”: “0”,
      “outside”: “1”
      “internal”: {
      “temperature”: “25.4”
      “channel1”: {
      “temperature”: “2.4”,
      “humidity”: “46” },
      “channel2”: {
      “temperature”: “”,
      “humidity”: “”
      “channel3”: {
      “temperature”: “”,
      “humidity”: “”
      “channel4”: {
      “temperature”: “”,
      “humidity”: “”
      I can’t find am module for this, does anyone have a solution to my Problem?
      • E Offline
        E3V3A
        Maybe this one ?
        "Everything I do (here) is for free – altruism is the way!"
        • G Offline
          Gasoman
          Great, thanks, I will try to read the data and then present it correctly. I would like to take the presentation of MMM-FHEM for it.
          • G Offline
            Gasoman @Gasoman
            @Gasoman
            next Problem, wenn the MagicMirror started it shows “Error fetching stats.” It display then the komplet string. What can I do?
