Newbe help please
It looks like my MagicMirror is running (see below) but the MagiciMirror screen doesn’t start.
pi@raspberrypi:~/MagicMirror $ pm2 restart MagicMirror Use --update-env to update environment variables [PM2] Applying action restartProcessId on app [MagicMirror](ids: 0) [PM2] [MagicMirror](0) ✓ ┌─────────────┬──────┬────────┬─────┬─────┬───────────┐ │ Name │ mode │ status │ ↺ │ cpu │ memory │ ├─────────────┼──────┼────────┼─────┼─────┼───────────┤ │ MagicMirror │ fork │ online │ 159 │ 66% │ 11.2 MB │ └─────────────┴──────┴────────┴─────┴─────┴───────────┘ Use `pm2 show ` to get more details about an appEverything was working fine from the original install (I even added a module w/o issues) till I followed the instructions to Disabling the screensaver and Disable WiFi Power Save.
Since I have a RPi 3 (Raspbian Stretch) I used the following instruction:
For RPi 3 (Raspbian Stretch)
We no longer have any default entries in /etc/network/interfaces, instead we make a plugin to the (service) startup script. Copy paste the following into you terminal:
cat << EOF | sudo tee /etc/network/if-up.d/off-power-manager > #!/bin/sh > # off-power-manager - Disable the internal power manager of the (built-in) wlan0 device > # Added by MagicMirrorSetup > iw dev wlan0 set power_save off > EOF #!/bin/sh # off-power-manager - Disable the internal power manager of the (built-in) wlan0 device # Added by MagicMirrorSetup iw dev wlan0 set power_save offThen set the permissions and reload the network daemon.
sudo chmod 755 /etc/network/if-up.d/off-power-manager sudo /etc/init.d/networking restartYou don’t need to reboot for this to take effect, but do it anyway to make sure it works. After reboot and your wifi is back up, test with:
iw dev wlan0 get power_saveAfter this the MagicMirror stopped starting up when
pm2 star MagicMirroris executed.
Any help you could offer to troubleshoot this is much much appreciated.
Thanks, -
Is there a screen connected to the pi? What is it showing?
Are you working directly on the pi, are you connecting via VNC or are you sshing to the pi?If you run
pm2 stop MagicMirrorand then trynpm startinside MagicMirror folder (if directly on the pi) orDISPLAY=:0 nohup npm start &(if connected via ssh), do you see the MagicMirror? -
@yawns Thanks for the prompt replay. Yes HDMI screen is connected and shows Pi OS desktop.
I am connected via VNC but I can also work directly on the Pi. Not really sure how to use SSH yet.I run
DISPLAY=:0 nohup npm start &inside the MM folder from VNC and MagicMirror screen started!!
I also runnpm startfrom Pi and works.
MagicMirror doesn’t start on reboot though. Reboot goes strait to desktop.
I guess my confusion is that before I just execpm2 start MagicMirror"and the MagicMirro screen start while now I will need to run
npm startCan you please explain why this happens and how I can have MagicMirror starts at boot again?
Thanks so much for your help.
@morso IDK how old is your MM that was working, but now you need to go to:
~/MagicMirror/installers/and run the mm.sh script with pm2. I use an alias for this:alias mm2='cd $HOME/MagicMirror/installers/; pm2 flush; pm2 start mm.sh && cd $OLDPWD'with:
$ cat ~/MagicMirror/installers/mm.sh cd ~/MagicMirror DISPLAY=:0 npm start -
@E3V3A Thank you very much!!
