    Calendar module has a problem with repeating calendar entries
    5 Posts 5 Posters 2.6k Views 6 Watching
    • W
      WillemW
      I am using the default calendar module to show events and birthdays. For this it links to a google calendar. In this calendar I record the events and birthdays on the day they started and repeat them annually. When I record more than three events/birthdays in the calendar the module stops showing any information from this calendar. My config looks like this:
      		header: "Festivities",
      			timeFormat: "absolute",
      			maximumEntries: '10',
      			maxTitleLength: '20',
      			displayRepeatingCountTitle: 'true',
      					symbol: "birthday-cake",
      					repeatingCountTitle: "jaar",
      					url: "https://calendar.google.com/calendar/ical/1egmps6ppemii2f82svtu4nbfg%40group.calendar.google.com/private-ab0550be85d14d2a20c24c4eebd4e97e/basic.ics",
      					symbol: "flag",
      					url: "https://calendar.google.com/calendar/ical/e805v9vdbqh12san27amedqlt0%40group.calendar.google.com/private-8b974556875b59299eeccfa118c1872d/basic.ics",
      					symbol: "flag",
      					url: "https://calendar.google.com/calendar/ical/nl.dutch%23holiday%40group.v.calendar.google.com/public/basic.ics",
      For debugging I created two calendars the first has three events the second has the same events including a fourth one. You can check this with curl -L . The information in the calendars is fake and only there for debugging purposes. The calendars will be deleted when the issue is fixed so feel free to use them for debugging.
      Can somebody let me know what I am doing wrong or check if there is something in the module code that explains this behaviour. Thank you.
      • thymonT
        thymon
        • W
          WillBuden
          Has this been resolved? I’m having the same problem.
          Bill B
            Buccaneeruk
            I am having the same issue, using a 365 ical certain entries show others dont, the ones that dont tend to be annual recurrence
            • BKeyportB
              BKeyport Module Developer
              Repeating events in the default calendar app is currently bugged out from all sides. In my case, they’ll show a day early, and show events that flat out don’t exist, but per the repeating calendar rule should (Example, Monthly event on the 3rd Tuesday of the month, except July - July is deleted manually from the cycle)
              It appears to me that they’ve decided to read the initial repeating event, and use that data to populate the others, right or wrong.
