Not reading RSS
9 Posts 2 Posters 3.6k Views 2 Watching
  • G Offline
    goncalovsc
    Im trying to put this RSS (http://www.cmjornal.pt/rss) but the module just stays on “loading”
    Any guesses?
    N 1 Reply Last reply Mar 15, 2018, 2:20 AM Reply Quote 0
    • N Offline
      ninjabreadman @goncalovsc
      @goncalovsc Does the default config work, showing NYT headlines?
      module: "newsfeed",
      position: "bottom_bar",
          feeds: [{
            title: "New York Times",
            url: "http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml",
      What happens when you run the following in the terminal from your MM?
      curl http://www.cmjornal.pt/rss
      Does this mean you succeeded in installing MM given your earlier post?
      • G Offline
        goncalovsc
        Yeah, i installed an older version of raspian and it worken now, 2 months later. With the NY Times it works, but with my RSS it just stays on loading
        • G Offline
          goncalovsc
          @ninjabreadman said in Not reading RSS:
          I understood what you meened now, i runned that command and it loaded the RSS, but in the magicMirror app just says loading
          N 1 Reply Last reply Mar 16, 2018, 1:56 AM Reply Quote 0
          • N Offline
            @goncalovsc That was just to check that the MM could reach cmjornal.pt.
            Hmm, if it works with NYT, it may have a problem parsing your RSS feed. Start your MM with npm start dev to see errors in both Terminal and the Chrome/Electron JavaScript console.
            The RSS feed contains errors, but it still loads for me:
            • G Offline
              goncalovsc
              This is my newsfeed.js file
              // Default module config.
              	defaults: {
              		feeds: [
              				title: "Ultimas Noticias",
              				url: "http://www.cmjornal.pt/rss",
              				encoding: "UTF-8" //ISO-8859-1
              		showSourceTitle: true,
              		showPublishDate: true,
              		showDescription: false,
              		wrapTitle: true,
              		wrapDescription: true,
              		truncDescription: true,
              		lengthDescription: 400,
              		hideLoading: false,
              		reloadInterval: 5 * 60 * 1000, // every 5 minutes
              		updateInterval: 10 * 1000,
              		animationSpeed: 2.5 * 1000,
              		maxNewsItems: 0, // 0 for unlimited
              		ignoreOldItems: false,
              		ignoreOlderThan: 24 * 60 * 60 * 1000, // 1 day
              		removeStartTags: "",
              		removeEndTags: "",
              		startTags: [],
              		endTags: [],
              		prohibitedWords: []
              	// Define required scripts.
              	getScripts: function() {
              		return ["moment.js"];
              Any idea why its stuck on loading?
              N 1 Reply Last reply Mar 16, 2018, 10:08 PM Reply Quote 0
              • N Offline
                @goncalovsc Is that your full newsfeed.js file? That is definitely not the complete file. Suggest running git checkout ~/MagicMirror/modules/newsfeed.js in Terminal.
                Best practice is to not edit your module files (e.g. newsfeed.js). Instead, override the defaults with your own settings in config/config.js.
                • G Offline
                  goncalovsc
                  Thanks for the help, it was an “http://” that was missing :p
                  But Now i have the se=ame problem that you had, a lot of "?"appears in special caracthers like “ç”, “ó”, etc.
                  Any solution?
                  • G Offline
                    goncalovsc
                    I discovered now how to fix, just changed the encoding in both files and its working
