Not reading RSS
9 Posts 2 Posters 3.7k Views 2 Watching
  • N Offline
    ninjabreadman @goncalovsc
    @goncalovsc Does the default config work, showing NYT headlines?
    module: "newsfeed",
    position: "bottom_bar",
        feeds: [{
          title: "New York Times",
          url: "http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml",
    What happens when you run the following in the terminal from your MM?
    curl http://www.cmjornal.pt/rss
    Does this mean you succeeded in installing MM given your earlier post?
    • G Offline
      goncalovsc
      Yeah, i installed an older version of raspian and it worken now, 2 months later. With the NY Times it works, but with my RSS it just stays on loading
      • G Offline
        goncalovsc
        @ninjabreadman said in Not reading RSS:
        I understood what you meened now, i runned that command and it loaded the RSS, but in the magicMirror app just says loading
        N 1 Reply Last reply Mar 16, 2018, 1:56 AM Reply Quote 0
        • N Offline
          @goncalovsc That was just to check that the MM could reach cmjornal.pt.
          Hmm, if it works with NYT, it may have a problem parsing your RSS feed. Start your MM with npm start dev to see errors in both Terminal and the Chrome/Electron JavaScript console.
          The RSS feed contains errors, but it still loads for me:
          • G Offline
            goncalovsc
            This is my newsfeed.js file
            // Default module config.
            	defaults: {
            		feeds: [
            				title: "Ultimas Noticias",
            				url: "http://www.cmjornal.pt/rss",
            				encoding: "UTF-8" //ISO-8859-1
            		showSourceTitle: true,
            		showPublishDate: true,
            		showDescription: false,
            		wrapTitle: true,
            		wrapDescription: true,
            		truncDescription: true,
            		lengthDescription: 400,
            		hideLoading: false,
            		reloadInterval: 5 * 60 * 1000, // every 5 minutes
            		updateInterval: 10 * 1000,
            		animationSpeed: 2.5 * 1000,
            		maxNewsItems: 0, // 0 for unlimited
            		ignoreOldItems: false,
            		ignoreOlderThan: 24 * 60 * 60 * 1000, // 1 day
            		removeStartTags: "",
            		removeEndTags: "",
            		startTags: [],
            		endTags: [],
            		prohibitedWords: []
            	// Define required scripts.
            	getScripts: function() {
            		return ["moment.js"];
            Any idea why its stuck on loading?
            N 1 Reply Last reply Mar 16, 2018, 10:08 PM Reply Quote 0
            • N Offline
              @goncalovsc Is that your full newsfeed.js file? That is definitely not the complete file. Suggest running git checkout ~/MagicMirror/modules/newsfeed.js in Terminal.
              Best practice is to not edit your module files (e.g. newsfeed.js). Instead, override the defaults with your own settings in config/config.js.
              • G Offline
                goncalovsc
                Thanks for the help, it was an “http://” that was missing :p
                But Now i have the se=ame problem that you had, a lot of "?"appears in special caracthers like “ç”, “ó”, etc.
                Any solution?
                • G Offline
                  goncalovsc
                  I discovered now how to fix, just changed the encoding in both files and its working
