    Current Weather module not working
    8 Posts 4 Posters 6.0k Views 4 Watching
    • A
      amped24
      var config = {
      	port: 8080,
      	language: "en",
      	timeFormat: 12,
      	units: "imperial",
      			module: "alert",
      			module: "updatenotification",
      			position: "top_bar"
      			module: "clock",
      			position: "top_left"
      			header: "US Holidays",
      						symbol: "calendar-check-o ",
      			module: "compliments",
      			position: "lower_third"
      			module: "currentweather",
      				locationID: "5074472",  //ID from http://www.openweathermap.org/help/city_list.txt
      				appid: "d2c62a1048cc5a3a2e586597ce29dc45"
      			module: "weatherforecast",
      			header: "Weather Forecast",
      				appid: "9ab5aef55af5581932e453668b57dd2b"
      				module: 'random_quotes',
      				position: 'bottom_bar',
      						// The config property is optional
      						// Without a config, a random quote is shown,
      						// selected from all of the categories available.
      			module: "newsfeed",
      			position: "bottom_bar",
      				feeds: [
      						title: "New York Times",
      				showSourceTitle: true,
      				showPublishDate: true
      	module: 'MMM-Globe',
      	position: 'center',
      		style: 'geoColor',
      		imageSize:400 ,
      		ownImagePath:'',
      		updateInterval: 10*60*1000
          			module: 'MMM-ATM',
         			 position: 'top_left',              // Works well anywhere
      				multipleChoice: "Yes",        // No = just the ? then the answer
      				useHeader: true,              // true if you want a header
      				header: "Not another trivia module!",   // Any text you want
      				maxWidth: "250px",             // Stretch or constrain according to region
      	module: "MMM-cryptocurrency",
      		currency: ['ethereum', 'bitcoin', 'monero'],
      		conversion: 'USD',
      		showUSD: false,
      		headers: ['change24h', 'change1h', 'change7d'],
      		displayType: 'logoWithChanges',
      		showGraphs: true
        mattmurf
        @amped24 said in Current Weather module not working:
        I had the same problem and seem to have fixed it. Try setting the initialLoadDelay to 1000.
        Here’s the section from the release notes.
        initialLoadDelay The initial delay before loading. If you have multiple modules that use the same API key, you might want to delay one of the requests. (Milliseconds)
        Possible values: 1000 - 5000
        Default value: 0
          mattmurf
          Disregard my post. The modules stopped working again this morning and I haven’t had time to look at any logs before heading in to work.
          • Y
            yawns Moderator
            I guess it’s the same error as here: https://forum.magicmirror.builders/topic/6878/changing-units-from-metric-to-imperial-breaks-currentweather-module/2
            M 1 Reply Last reply
              mattmurf @yawns
              @yawns Thanks! That’s helpful and I’ll give it a look tonight.
              The odd bit is that mine started working after I made the change and then stopped.
                sefeing
                Just started having this same issue when I updated magic mirror. The forecast works fine, but the Current weather does not show. Any updates / have you solved?
                  mattmurf @sefeing
                  @sefeing My Current Weather was working again this morning without making any config changes after restarting the module.
                    sefeing
                    Odd… mine hasn’t… Is there a way to manually restart the module?
                    Edit: Seems to be related to that metric to imperial thread. If I switch to metric, it loads fine, but imperial breaks It.
                    What was the solution to that?
