    Get pictures from synology NAS - "Rediscover This Day"
    9 Posts 5 Posters 5.7k Views 7 Watching
      cyberphox
      Own a Synology and would LOVE to do this!! Contact me for sure…interested!!
        schmucke
        i help me here very simple. on the Magicmirror side, i have a cronjob what get pictures every day per ssh/scp. To use this, i have add the magicmirror device to the knownhosts on the synology side (google for it).
        on Synology side:
        This Script is get the exif data of the images. write it to a CSV and then, get the path and write it to a mysqldb (This Script i run once every year one time per hand … i dont know it works perfectly… I think, that here are better coding people… this is quick and dirty. But it works for me. I cant show the Magicmirror side now, i am not at home - but you can use every Plugin with a upload folder… i can show my “Plugin” in the next days if you want…
        #!/bin/bash
        # This script is get the exif data (if set) from all
        # pictures (jpg/JPG) in a define path (recursiv).
        # It writes the data to am MYSQL Database.
        # It works native with Synology DSM (Tested with 6.0.2-xxxx)
        # To use this script, put in the  root folder of your photos
        # chmod 775 ./listimages.sh make the script executable
        # ./listimages.sh execute the scriptfile
        # Where want you present your files?
        imagepath=/volume1/Intern/Fotos/MagicMirror/
        # Variables for the temp files (will delete at End of the Script
        exportcsv=./export.csv
        importcsv=./import.csv
        # MySql Data
        username=root
        password=PASSWORD
        database=ExifData
        table=Bilder
        shopt -s globstar extglob
        exiv2 -pa -g DateTimeOriginal **/*.@(jpg|JPG) |
        awk -v pwd="$PWD/" -v dq='"' -v OFS=',' '{
            fn = substr($0, 1, match($0, / *Exif\.Photo/)-1)
        	    print dq pwd fn dq,  dq $(NF-1) dq, dq $NF dq
        		}' >$exportcsv
        mysql -u$username -p$password -e "use $database" -e "
        TRUNCATE Bilder;"
        # Write data to mysql
        for f in $exportcsv
        do
        		LOAD DATA LOCAL INFILE '$f'
        		INTO TABLE $table
        		FIELDS TERMINATED BY ','
        		OPTIONALLY ENCLOSED BY '\"'
        		LINES TERMINATED BY '\n'
        		(path,date,time);"
        done
        This script is copying and resizing the images:
        importcsv=/volume1/Intern/Fotos/Bilder/import.csv
        #remove old images
        rm /volume1/Intern/Fotos/Bilder/import.csv
        rm /volume1/Intern/Fotos/MagicMirror/*.*
        #Get Date from tommorow
        DATE=$(date --date='1 day' +%m-%d)
        #DATE=$(date +%m-%d)
        #MYSQL Query by date from tomorrow
        id=$(mysql -uroot -pPASSWORD -s -N -e "SELECT path FROM ExifData.Bilder WHERE date like '%$DATE' INTO OUTFILE '$importcsv' FIELDS TERMINATED BY ',' ENCLOSED BY ''")
        # Copy files with exifdata from tomorow before one,two, three or whatever years
        while read p; do
        cp "$p" $imagepath
        done < $importcsv #(DELETE THE SPACE BETWEEN < AND $!!!!)
        cd $imagepath
        shopt -s nullglob
        i=0
        for f in *.JPG *.jpg *.jpeg; do
          exiv2 -r "$i"_%d.%m.%Y_%H.%M.%S rename ./"$f"
          i=$((i+1))
          done
        	convert -thumbnail 800 ./"$f" ./"${f%}.jpg"
        	rm ./"$f"
        done
        I hope this helps - you can do it! Have fun!
        • T Offline
          Tifendro
          Awesome ! I will try this soon !! Thank’s again !
          • T Offline
            Tifendro
            what about your photo plugin ?
            • yawnsY Offline
              yawns Moderator @Tifendro
              @Tifendro
              https://github.com/roramirez/MMM-ImagesPhotos
                schmucke
                Yes @yawns,
                this is the plugin what i use. i have only customize the css stuff.
                • G Offline
                  Gabev
