    MMM-Loxone
    loxonesmart home
    94 Posts 11 Posters 92.8k Views 14 Watching
      bobbythemoh
      GREAT this is what i am looking for aswell.
      A feature i would like to see would be: My mirror is in the bathroom, so i am not in this room on regular basis. It would be nice if the motion sensor in the bathroom is activated that the monitor comes alive. After a certain activity period in the bathroom the MM should go back to “energy saving” -->either a screensaver or shutting off the monitor.
      Awesome work dude, looking forward for the module!
      Thanks Robert
      idoodlerI 2 Replies Last reply Reply Quote 0
      • idoodlerI Offline
        idoodler Module Developer @bobbythemoh
        @bobbythemoh Yes, I was already thinking about that I will add this for sure!
        • idoodlerI Offline
          @bobbythemoh Here is my implementation idea.
          The user enters the room, the MagicMirror awakes and keeps activated untill the light goes out.
          I have no idea to connect the Loxone Presence detector with the MagicMirror in an easy to configure way.
            bobbythemoh
            It would be nice if the module can work with udp commands. I would suggest sending „activity in room“ plus an integer and this is the alive time for the magic mirror.
            idoodlerI 1 Reply Last reply Reply Quote 0
            • idoodlerI Offline
              @bobbythemoh This seems like a solution for thinkerers. I want solutions for everyone using built-in function from the Loxone eco system.
              • idoodlerI Offline
                I just published the module, please try it out and file feature requests:)
                [card:idoodler/MMM-Loxone]
                  bobbythemoh
                  Hi, i tried to install the module today but i cant run it.
                  Please find attached a screenshot with a waring when i ran “npm install” and secondly the config i add in config.js
                  The magic mirror shows me that there is an error in the config.js
                  Thanks for the help!
                  • idoodlerI Offline
                    @bobbythemoh Please check your config.json this is not a valid object. Your config should look like this:
                        host: '192.168.0.200',
                        user: 'MagicMirror',
                        pwd: 'YOUR_PW'
                    You are missing both the : and ,.
                    Everything should be fine after you corrected the config.json. Your first screenshot just shows the correct installation process, you can ignore the WARN messages.
                      bobbythemoh
                      Hey, the first thing i have observerd so far is the power consumption of the Magic Mirror. Without Monitor i measure approx. 5 Watts, and if the monitor is on i measure 45W. The system was now running for some hours, but the monitor does not switch to “standby” mode. any ideas?
                        bobbythemoh
                        Hi, the mirror looks like that right now:
                        I dont see the temperature in the “current weather” module
                        How can i check, if the communication to loxone is working? Motion sensor activation does not work aswell.
                        I think i am doing something wrong.
                        • 10
                        • 1 / 10
