    MMM-Loxone
    loxonesmart home
    94 Posts 11 Posters 92.8k Views 14 Watching
    • idoodlerI Offline
      idoodler Module Developer
      Hi everyone!
      I am owning a Loxone Smart Home, but I couldn’t find a compatible module for Loxone.
      So decided to work on MMM-Loxone.
      It enables other modules to communicate with your Loxone Miniserver via a secure connection with token based authentication, so no unsecure basic authentication!
      Right now the Loxone module doesn’t have any UI, but it emmits the INDOOR_TEMPERATURE notification which enables other modules like default Current Weather Module, or my fork of MMM-forecast-io to display the room temperature without adding yet another module.
      Current Features:
      • Emmit INDOOR_TEMPERATURE (The room temperature the MacigMirror is located in, ready to use for other modules). Just define the room, the module will automatically figure out the temperature of the room, given you use an “Inteligent Room Controller” in this room!
      • Show notifications (info, error, system and notifications of controls) using the default, alread installed alert module
      • Lets other modules communicate with your Loxone Miniserver (You must explicitly enable this in your config.json)
      What do you think about this module, are you exited, do you miss any feature? I am planing on releasing this module within the next week.
      Update:
      • Define a virtual output that enables/ disables the Interface of the MagicMirror
      • Blank out the screen also works on web interface only installations
      • Stability improvements (Will automatically reconnect in case of a reboot due to an update)
      [card:idoodler/MMM-Loxone]
        bobbythemoh
        GREAT this is what i am looking for aswell.
        A feature i would like to see would be: My mirror is in the bathroom, so i am not in this room on regular basis. It would be nice if the motion sensor in the bathroom is activated that the monitor comes alive. After a certain activity period in the bathroom the MM should go back to “energy saving” -->either a screensaver or shutting off the monitor.
        Awesome work dude, looking forward for the module!
        Thanks Robert
        idoodlerI 2 Replies Last reply Reply Quote 0
        • idoodlerI Offline
          idoodler Module Developer @bobbythemoh
          @bobbythemoh Yes, I was already thinking about that I will add this for sure!
          • idoodlerI Offline
            @bobbythemoh Here is my implementation idea.
            The user enters the room, the MagicMirror awakes and keeps activated untill the light goes out.
            I have no idea to connect the Loxone Presence detector with the MagicMirror in an easy to configure way.
              bobbythemoh
              It would be nice if the module can work with udp commands. I would suggest sending „activity in room“ plus an integer and this is the alive time for the magic mirror.
              idoodlerI 1 Reply Last reply Reply Quote 0
              • idoodlerI Offline
                @bobbythemoh This seems like a solution for thinkerers. I want solutions for everyone using built-in function from the Loxone eco system.
                • idoodlerI Offline
                  I just published the module, please try it out and file feature requests:)
                    bobbythemoh
                    Hi, i tried to install the module today but i cant run it.
                    Please find attached a screenshot with a waring when i ran “npm install” and secondly the config i add in config.js
                    The magic mirror shows me that there is an error in the config.js
                    Thanks for the help!
                    • idoodlerI Offline
                      @bobbythemoh Please check your config.json this is not a valid object. Your config should look like this:
                          host: '192.168.0.200',
                          user: 'MagicMirror',
                          pwd: 'YOUR_PW'
                      You are missing both the : and ,.
                      Everything should be fine after you corrected the config.json. Your first screenshot just shows the correct installation process, you can ignore the WARN messages.
                        bobbythemoh
                        Hey, the first thing i have observerd so far is the power consumption of the Magic Mirror. Without Monitor i measure approx. 5 Watts, and if the monitor is on i measure 45W. The system was now running for some hours, but the monitor does not switch to “standby” mode. any ideas?
                        • 10
                        • 1 / 10
