    How to convert weatherforecast disaplay
    9 Posts 7 Posters 3.3k Views 8 Watching
    • N Offline
      nobita
      I would like to convert weatherforecast (from Default module) form vertical to Horizontal like the photo.
      someone help me to convert, Thanks so much
      M kruemelK 2 Replies Last reply Reply Quote 0
        mkastern @nobita
        @nobita Did you ever get this figured out?
        • kruemelK Offline
          kruemel
          I did not tried but with MMM-MyWeather you can configure horizontal.
          Maybe it’s what you’r looking for :-)
            mkastern @kruemel
            @kruemel - I have used that version to display a horizontal table of the extended forecast, but it isn’t in a format that looks as nice as the above picture. I am considering modifying a different weather module that has better formatting, but was checking to see if someone else has already gone through that effort first.
            • kruemelK Offline
              kruemel @nobita
              @mkastern Maybe you are still interested.
              I tested alot for an idea i had and now i just modified the weatherforecast.css to get this result (top left):
              Made this changes:
              td {
                display: block;
                padding-right: 25px
              tr { display: inline-block;}
              .weatherforecast .day {
                padding-left: 5px;
              .weatherforecast .weather-icon {
                padding-left: 5px;
              .weatherforecast .max-temp {
              .weatherforecast .min-temp {
              But keep in mind, after an update of MM, your changes get overwritten because it’s an integrated module!
                redeyes
                Hi
                I managed to created something similar with the help of chatgpt let me know if interested
                M E 2 Replies Last reply Reply Quote 0
                  miguelcartagena @redeyes
                  @redeyes can you please share the css/js configuration you have? I’m interested on having a horizontal bar for weather forecast just like yours.
                    CharlesBarden
                    Can you please let us know which format are you trying to covert the weather forecast?
                    • E Offline
                      Eli @redeyes
                      @redeyes wow, looks good!
                      I would also be interested in that changes. Is that uploaded somewhere already?
