    Problem with MMM-Button
    6 Posts 4 Posters 2.5k Views 4 Watching
      maydaymiao
      Hi, I am trying to work with MMM-Button but met some problems. I have connected a push button to GPIO 5 and tested with Python script without any problem.
      But magic mirror logs continously throws me the error whenever I push the button. Here is the screen shot from both the mm logs and part of my config file. Thanks for your help!
      • F Offline
        fikol
        I have the same problem.
        Did you solve that?
          AxLed Module Developer
          there is a second Module MMM-Buttons (see last s) which worked for me.
          AxLED
          • F Offline
            fikol
            Hello, I have found fault. In node helper.js, I replaced the entry (this.config.notificationMessage, true) with (“BUTTON_PRESSED”, true).
            • E Offline
              E3V3A
              Can you provide links to both those button modules, please?
              "Everything I do (here) is for free – altruism is the way!"
                Here you go:
                https://github.com/ptrbld/MMM-Button
                and
                https://github.com/Jopyth/MMM-Buttons
                AxLED
