    Navigation inside MagicMirror with Buttons / Rotary Encoder on GPIO
    11 Posts 3 Posters 9.9k Views 3 Watching
    • A
      AxLed Module Developer
      i started creating a html file with javascript, which responses on keyboard action.
      So far i check for 3 Keys: Arrow Up, Arrow Down and Enter.
      For testing:
      • i showmy html site (navigation.html) in module MMM-iFrame.
      • i call MM via Webbrowser from a PC
      • i have to set the focus in the MMM-iFrame Window first
      • now i can “scroll to my pages” and “show details on Newsfeed” (realized via Hyperlinks of MMM-Remote-Control)
      Screenshot:
      Code of navigation.html:
      (@moderator: i dont have the permission to upload that 13KB HTML File, can you help me?)
      So the first steps are made, i hope that “Website javascript” can somehow be translated to javascript code which can be handled by MM needs it.
      AxLED
      • A
        Hi to the builders,
        i made some progress.
        • i connected 3 buttons to my RPI1 (my TestPi, as my pixel VM doesnt have GPIO)
          • arrow up
          • arrow down
          • enter
        • installed pikeyd (to map GPIO Buttons to keyboard press, as my navigation.html works with javascript which interacts with keyboard press)
        • modified css and javascript on navigation.html, so i grab focus on loading and hide after x milliseconds (navigation shows back on button press)
        Requirements (so far):
        • MMM-Remote-Control (as i use hyperlinks to navigate)
        • MMM-IFrame (to show my navigation.html)
        • pikeyd (https://github.com/mmoller2k/pikeyd)
        Here are some screenshots:
        I still have some problems:
        • loosing focus on navigation.html, after “Button Enter” at Chromium on RPI1 via VNC (Webbrowser of Win PC works with keyboard press an keeps focus after pressing enter), maybe this works on RPI3 (my productive environment)
        Is there someone who can help me to put this in a module?
        I like the idea, to navigate through my MM using only 3 buttons (planed: Rotary Encoder)
        Regards
        AxLED
        • PatexP
          Patex
          @AxLed said in Navigation inside MagicMirror with Buttons / Rotary Encoder on GPIO:
          What help exactly do you need? I haven’t taken a look but it seems like a nodejs library for rpi gpios exists making it a completely viable solution.
          A heads up: don’t hack your solution depending on iframe and remote control. Everything you described is natively possible and jumping through many hoops will only introduced bugs and glitches.
          Gib mir bescheid woran genau es momentan scheitert und ich kann dir sicher den ein oder anderen Anstoß geben.
          • A
            because of suggestion of some users, i try to write my own module and need some help.
            I have a working html file with following components:
              1. css
              1. html
              1. script source in html site: http://code.jquery.com/jquery-1.7.2.min.js
              1. javascript in html site, to react on some interaction
            navigation.html in action:
            I tried to reconstruct the html file as a MMM-Module, with some succuss and some failure.
            Success:
            10. css
            20. html
            Failure:
            30. script source in html site: http://code.jquery.com/jquery-1.7.2.min.js
            Problem 1: I tried getScripts to load it
            getScripts: function() {
            		return [
            			'http://code.jquery.com/jquery-1.7.2.min.js', //js laden
            but i dont know if loading worked an how i can test it.
            Problem 2: I have javascript code in my html file, but i dont know where and how to place it in my module.js file
            Maybe somebody can help me or give me some hints.
            Regards
            AxLED
            @moderator: maybe this topic can be moved to ‘modules -> development’
            • Y
              yawns Moderator
              Moved as requested :)
              • A
                thank you yawns
                • A
                  i made some progress to the following problem:
                  30. Failure: script source in html site: http://code.jquery.com/jquery-1.7.2.min.js
                  		return [
                  Solution: F12 Debugger (Firefox) shows “Load script: http://code.jquery.com/jquery-1.7.2.min.js in loader.js:182:4”.
                  So i know (guess) it works.
                  Now i moved to the next problem, i tried to use
                  addEventListener
                  in my .js code to react on mouseover, to color hyperlinks red (just an example to test how and if it works). One of my 4 links turn red (always the last one), could this be because i create my links in a “for loop” and addEventListener just grabs the last one?
                  Looking forward hearing from you.
                  Greets AxLED
                  • A
                    Hi to all,
                    i made some progress, i solved following topics:
                    • i got addEventListener working (it now listens to Keyboard inputs so far, Future: GPIO PINs)
                    • i dont have a need for jQuery anymore (reduces complexity)
                    • i improved the navigation-actions from http-Links (to MMM-Remote-control) to direct using sendnotifications (reduces complexity and dependencies)
                    and i still have some problems (challenges):
                    • how can i set the focus on a div on my module afer MM finished loading? I need this so my keyboard keypresses are recognised. (Setting the focus manual by mouse let my module work).
                    Maybe someone can help me or give me some tips.
                    Regards AxLED
                    • A
                      Hi to all,
                      i made some further progress, i solved following topics:
                      • i don’t need to set focus on a div anymore after loading MM, as GPIO Input can directly interact with my navigation
                      • i replaced the keyboard eventlistener by GPIO Inputs of a rotary encoder
                      • i wrote a node_helper.js for the rotary encoder
                      • the module has only one depencie - onoff
                      So my module is beta or alpha so far, is there a special way to put it on github or can somebody explain it to me, how to do it, so i can put the module online.
                      Partlist for using this module:
                      • Rotary encoder (KY-040)
                      • 3 free GPIO Pins on raspberry
                      Regards AxLED
                      • A
                        Hi to all,
                        i finished the first version of my module, detail see: MMM-Navigate
                        AxLED
