RPI and HDMI->VGA converters..
7 Posts 3 Posters 4.4k Views 3 Watching
  • G Offline
    gshimself
    Hi guys. Im in need of your help.
    Since I’ve build my mirror I have used 3 different HDMI -> VGA converters. (I got a http://www.ebay.com/itm/LCD-Controller-Board-DIY-Kit-RTD2270L-Driver-LVDS-Inverter-Turn-LCD-to-Monitor-/110925504614 as a endpoint).
    The first converter had a external powersupply. It work… For a day. Then it started blinking/flashing and was unstable pitchure and I saw that my mirror did not enjoy it. Bad power voltage and so on.
    Next converter i used is bugged on the RGB scale and shows the green color ALL THE TIME. This means some problems.
    Now, now I have bought a legit HDMI>vga converter from “The Pi Hut” or something. Now I only get “NO SIGNAL” on my display. And even on my regular TV-display
    I know that the converter works (tried in my computer and PS4) But It’s just my RPI2 that it doesnt work on… I have googled far and beyond with no resualts. I have tried edit the “/boot/config” file but no help…
    To the question: Have anyone been in my position? Does anyone know why this happend? RPI power problems? is it the LCD Controllerboard togheter?
    • G Offline
      gshimself
      Update…
      Now I know it’s something to do with my RPI… I borrowed a friends RPI (with my screen, SD-card, converter, enverything) it works like a charm. And he got the same RPI model.
      Someone know what could fix the problem?
      • K Offline
        kckndrgn
        Best i can say is, have you done an update and upgrade recently to your Pi (assuming you are on Rasbian or NOOBS OS)?
        sudo apt-get update
        sudo apt-get upgrade
        and make sure all drivers and configurations are current?
        Might start with a new installation of the Pi OS and go from there.
        May also need to try to find the differences in the configurations between your Pi and your friends.
        G 1 Reply Last reply Aug 31, 2016, 3:27 PM Reply Quote 0
        • G Offline
          gshimself @kckndrgn
          @kckndrgn Thanks for replying!
          I’ve done a update/upgrade but same resaults, and yes, I’ve reinstalled Jessie on my SD card. But before I reseted my SD-card I tried it in his RPI and it worked. So
          My card -> His RPI, WORKS
          His cars -> His RPI, WORKS
          My C -> my rpi, NO
          His C -> ^^^^, NO.
          So it’s something with my hardware to do but can’t figure out how and why… It’s not like there is a BIOS reset anywhere either. :(
          And the powersupply should be good when I’ve used the same stuff on his RPI when it works. It’s so weird. It’s just a video output.
          • K Offline
            kckndrgn
            Sounds like you have a bad Pi then.
            Don’t know if there is any support in the Pi/Linux world but maybe you can use a USB to VGA adapter? I’ve got one on my PC (running winblows) for a dual monitor setup.
            • K Offline
              Knox
              There is also this little beauty
              https://www.pi-supply.com/product/gert-vga-666-hardware-vga-raspberry-pi/
              it uses the gpio pins instead of the hdmi output.
              G 1 Reply Last reply Aug 31, 2016, 7:15 PM Reply Quote 0
              • G Offline
                gshimself @Knox
                @Knox I’ve thought about that but just that I’ve tried 3 different converters makes me mad when it doesn’t work for some unknown reason. But maybe I just have to accept it and buy one. :)
