    Rasbian Stretch screensaver disable
    5 Posts 3 Posters 2.9k Views 3 Watching
    • KimzerK
      Kimzer
      Hiyaaaaa. Having problems disabling the screensaver.
      Ive tried countless guides and none seem to work.
      Tried;
      Add these lines to /etc/xdg/lxsession/LXDE/autostart (LXDE-PI also)
      @xset s noblank
      @xset s off
      @xset -dpms
      Tried installing screensaver software and disabling it there. But all to no use.
      How do we do this properly in stretch?
        this Debian Stretch: deactivate screen blanking
        says
        add those lines to
        /home/pi/.config/lxsession/LXDE-pi/autostart
        note that is a file that is USER based…
        • KimzerK
          Kimzer
          I have done that, does not work :s
          • KimzerK
            Kimzer
            Is there a different method if ive changed to the opengl driver instead?
              MagicVolker
              maybe you have the same problem as me (and it’s not the screensaver).
              In /var/log/syslog i found this messages:
              Jun 13 07:12:41 raspberrypi kernel: [ 3057.339364] Out of memory: Kill process 1070 (electron) score 576 or sacrifice child
              Jun 13 07:12:41 raspberrypi kernel: [ 3057.339426] Killed process 1070 (electron) total-vm:673580kB, anon-rss:59472kB, file-rss:0kB, shmem-rss:214908kB
              Jun 13 07:12:41 raspberrypi kernel: [ 3057.373292] oom_reaper: reaped process 1070 (electron), now anon-rss:0kB, file-rss:0kB, shmem-rss:215056kB
              For me it looks like electron has crashed.
              After using google I’ve found a hint with other processes to change the value of vm.min_free_kbytes.
              You can find it in /etc/sysctl.d/98-rpi.conf.
              I’ved change the value to
              vm.min_free_kbytes = 1024
              After this there is no more blank screen anymore.
