Unsolved Microsoft To-Do (wunderlist replacement?)
@thobach thanks for your effort. Just got this up and running from your instructions in the README. Very pleased. :thumbs_up:
@thobach said in Microsoft To-Do (wunderlist replacement?):
I don’t plan to implement a fade-option, sorry, it would require quite some effort given the current implementation.
I have been able to add a fade-option by looking at how this option has been implemented in the MMM-nstreinen module by @qistoph. Since I am not familiair with JS coding I don’t know wether it has been coded as it should.
My addition takes two parameters from config.js: ‘fade’, which can be true or false and ‘fadePoint’, which takes a decimal value between 0 and 1 and marks the point where the fade starts.
I added the code after the listItem styling.
// needed for the fade effect itemCounter += 1 // Create fade effect. if (self.config.fade && self.config.fadePoint < 1) { if (self.config.fadePoint < 0) { self.config.fadePoint = 0; } var startingPoint = self.config.itemLimit * self.config.fadePoint; var steps = self.config.itemLimit - startingPoint; if (itemCounter >= startingPoint) { var currentStep = itemCounter - startingPoint; listItem.style.opacity = 1 - (1 / steps * currentStep); } }
@Mighty-Mouseq Nice! Do you want to create a pull request? I could then merge it into the main branch for everyone.
@thobach I do not consider myself a developer :-). I do not even have a GitHub account. If you prefer to implement this change through a pull request then I will have a look at the process. For such a minor change it might be a lot easier if you, or another developer, added the code in your repository.
@thobach I think I have created a pull request for the fade effect.
