    Microsoft To-Do (wunderlist replacement?)
    45 Posts 17 Posters 36.3k Views 19 Watching
    • T
      thobach @andyyy
      @andyyy The call seems to be missing some parameters, please check the full command line from https://github.com/thobach/MMM-MicrosoftToDo/blob/master/README.MD, thanks!
      • T
        thobach @zolabus
        @zolabus It seems you faced the same issue as in https://github.com/thobach/MMM-MicrosoftToDo/issues/18. I updated the instructions in https://github.com/thobach/MMM-MicrosoftToDo/blob/master/README.MD#refresh-token-generation-refresh-token to be more Windows friendly, e.g. all in a single line and using double quotes. Could you please try it again with the updated instructions? Thanks!
          smoysauce
          @thobach: Do you have recommendations to get the due date to show? I have tried to add element.dueDateTime.dateTime in the MMM-MicrosoftToDo.js like I have in the past, but now the module won’t show with that that. And no matter how I try to format it with moment it still doesn’t like it. I tried it with the simple element.id to see if that would show and it does show the todo ID. Thoughts? I know I am missing something simple. Thanks!
          lavolp3L 1 Reply Last reply
          • lavolp3L
            lavolp3 Module Developer @smoysauce
            @smoysauce if your element does not have a dueDateTime (null) this could lead to an error (cannot get property of undefined).
            Maybe something like this?
            if (element.dueDateTime) {
              var dueDate = moment(element.dueDateTime.dateTime).format("LL");
            How to troubleshoot modules
            MMM-soccer v2, MMM-AVStock
            S 2 Replies Last reply
              smoysauce @lavolp3
              @lavolp3 Oh good call-out! I tried your example as well as a few other tweaks but it doesn’t seem to like it when I add that snippet in. I don’t know why it’s being so weird. I’ll keep toying around with it, but any other thoughts would be appreciated!
                smoysauce @lavolp3
                @lavolp3 said in Microsoft To-Do (wunderlist replacement?):
                var dueDate = moment(element.dueDateTime.dateTime).format(“LL”);
                So after some tinkering, I figured out that the node.js was not pulling in the due date so I removed the ‘select’ filter so the call URL has '/tasks?$top='
                After that, I was able to add moment(new Date(element.dueDateTime.dateTime)).format("ddd MMM DD") to the output string and got the date to show. But for the life of me, I cannot get the var or if statements to work. If I try to use either the module doesn’t load. I have tried them in all different spots and it just doesn’t like it.
                • lavolp3L
                  @smoysauce
                  First, moment(new Date(element.dueDateTime.dateTime)).format("ddd MMM DD") is redundant. You don’t need the new Date part.
                  moment(element.dueDateTime.dateTime).format("ddd MMM DD")should be enough.
                  Second, where have you put it?
                  I had my own problems with the code, that’s why I’m working on an own version including due dates, but it’s not finished.
                  Here’s how I would try to include it.
                  if (this.list.length !== 0) {
                        this.list.forEach(element => (listItemsText += '<li style="list-style-position:inside; white-space: nowrap; overflow: hidden; text-overflow: ellipsis;">' + checkbox + element.subject + ((element.dueDate) ? moment(element.dueDateTime.dateTime).format("ddd MMM DD") : '') + '</li>'))
                      } else {
                        // otherwise indicate that there are no list entries
                        listItemsText += '<li style="list-style-position:inside; white-space: nowrap; overflow: hidden; text-overflow: ellipsis;">' + this.translate('NO_ENTRIES') + '</li>'
                    smoysauce @lavolp3
                    this.list.forEach(element => (listItemsText += ‘
                  • ’ + checkbox + element.subject + ((element.dueDate) ? moment(element.dueDateTime.dateTime).format(“ddd MMM DD”) : ‘’) + ‘
                    } else {
                    listItemsText += ‘
                  • ’ + this.translate(‘NO_ENTRIES’) + ‘
                    Thanks for pointing that out, I am still figuring things out and piecing things together and if they work I just stick with it! That snippet worked, I had to change the section element.dueDate to element.dueDateTime but other than that seems to be doing the trick. I’ll probably toy around with it a bit more to see if I can learn formatting it with CSS to left align the subject and right align the date. Thanks for the help and tips!
                    • O
                      open_book
                      @thobach thanks for your effort. Just got this up and running from your instructions in the README. Very pleased. :thumbs_up:
                      sudo insert motivational.quote
                        Mighty Mouseq @thobach
                        @thobach said in Microsoft To-Do (wunderlist replacement?):
                        I don’t plan to implement a fade-option, sorry, it would require quite some effort given the current implementation.
                        I have been able to add a fade-option by looking at how this option has been implemented in the MMM-nstreinen module by @qistoph. Since I am not familiair with JS coding I don’t know wether it has been coded as it should.
                        My addition takes two parameters from config.js: ‘fade’, which can be true or false and ‘fadePoint’, which takes a decimal value between 0 and 1 and marks the point where the fade starts.
                        I added the code after the listItem styling.
                        // needed for the fade effect
                                itemCounter += 1
                                // Create fade effect.
                                if (self.config.fade && self.config.fadePoint < 1) {
                                  if (self.config.fadePoint < 0) {
                        	          self.config.fadePoint = 0;
                        	        var startingPoint = self.config.itemLimit * self.config.fadePoint;
                        	        var steps = self.config.itemLimit - startingPoint;
                        	        if (itemCounter >= startingPoint) {
                                    var currentStep = itemCounter - startingPoint;
                                    listItem.style.opacity = 1 - (1 / steps * currentStep);
                        T 1 Reply Last reply
                        • T
                          thobach @Mighty Mouseq
                          @Mighty-Mouseq Nice! Do you want to create a pull request? I could then merge it into the main branch for everyone.
                          M 2 Replies Last reply
                            @thobach I do not consider myself a developer :-). I do not even have a GitHub account. If you prefer to implement this change through a pull request then I will have a look at the process. For such a minor change it might be a lot easier if you, or another developer, added the code in your repository.
                              @thobach I think I have created a pull request for the fade effect.
                              • 3 / 3
