    Microsoft To-Do (wunderlist replacement?)
    45 Posts 17 Posters 36.0k Views 19 Watching
      binderth @ThaliaFromPrussia
      @ThaliaFromPrussia jepp, did that (the client_id and stuff stays the same, but code regenerates. or did you delete your App as a whole?
      T 1 Reply Last reply
      • T
        ThaliaFromPrussia @binderth
        @binderth From the point with Azure on, including a new client ID.
        the refresh time is very fast. You set up a new task and within a few seconds it appeares on the screen.
        B 1 Reply Last reply
          @ThaliaFromPrussia ok - still nothing new, did a complete new App now.
          is there a way to get more Loginfos? right now I only get the helper and stuff in the log, but nothing more. no Authentication error or something, which would point me in the right direction…
          T M 2 Replies Last reply
          • T
            @binderth I can only guess that you’ll have a typo somewhere. Maybe someone else near you can compare what you got and what you typed?
            • T
              @binderth said in Microsoft To-Do (wunderlist replacement?):
              first: I think, the URL is broken (spaces here: https://github.com/thobach/MMM-MicrosoftToDo#authorization-code-generation-code).
              only after replacing the whitespaces with “%20” it worked and I got the code.
              For me the link worked as it is. What whitespaces do you mean?
              This might be helpful:
              @sdetweil said in no result from mvgmunich modul:
              @Babene1 open the developers window, using the keyboard, ctrl-shift-i, select the tab labeled ‘console’ and then scroll up… to find any errors (usually red text)
              you can also filter to messages from a single module, by putting some part of its unique name into the file labeled ‘filter’, like mvgm
              let us know what u find
              if you use pm2 to manage the mirror runtime, you might also look at the logs, by doing
              pm2 logs
                mherke @binderth
                @binderth
                …same issues here. i can’t get it running and i am missing an option to analyse the problem :(
                  Jan
                  Hi. I successfully impemented your module. Thx for you effort! I have one question: Is there any possibility to get data for several lists and sort them under the name of the list ? (like before with Wunderlist) .
                  • A
                    andyyy
                    I am having trouble setting up this module. At the point refresh token generation I am failing.
                    https://github.com/thobach/MMM-MicrosoftToDo/#refresh-token-generation-refresh-token
                    1). Open terminal app -> I tried the windows console, powershell and secure shell (on the PI), but everywhere I receive just errors as output.
                    Can someone give some guidance. Thanks.
                    • T
                      thobach @andyyy
                      @andyyy What error message do you get? Are you on Windows 10 which should have curl pre-installed? I updated the readme file to replace the space symbols with %20 as that seemed to have caused issues for some. Please make sure to preserve the ’ symbol at the end of the call.
                      A 1 Reply Last reply
                      • T
                        thobach @binderth
                        @binderth The refresh happens every 60s. I don’t plan to implement a fade-option, sorry, it would require quite some effort given the current implementation.
                        M 1 Reply Last reply
                        • T
                          thobach @Jan
                          @Jan You’re welcome. Have you tried adding the module multiple times in the config file with different listId values?
                          J 1 Reply Last reply
                          • T
                            thobach @binderth
                            @binderth Did the tips from @ThaliaFromPrussia (https://forum.magicmirror.builders/post/68615) work for you to see what error you are getting on the magic mirror front-end?
                              Jan @thobach
                              @thobach Thx for your reply. Your solution has not exactly the effect what i want, but it works fine for me ;-)
                              • A
                                andyyy @thobach
                                @thobach
                                curl -X POST https://login.microsoftonline.com/common/oauth2/v2.0/token
                                Length Required
                                Length Required
                                HTTP Error 411. The request must be chunked or have a content length.
                                I am sure curl is installed since other modules with OAuth are working as well.
                                • G
                                  geoffroff
                                  Hi
                                  Managed to get the default task list to show but cannot get any other list to show. It just States Loading Tasks but never changes. Selected the list from ToDo but the ‘ID’ is a lot shorter than the example given.
                                  Is there something I’m missing here?
                                  It seems like this should work but just having trouble getting it to link. Not overly impressed with ToDo yet but need a shared environment and this was the simple choice having previously used Wunderlist.
                                  Cheers
                                  G
                                  W 1 Reply Last reply
                                    mherke
                                    i followed the README.MD on github step by step and now i got it running :) i tried a few weeks ago several times without success and was pretty close to give up.
                                    thanks an kind regards!
                                    • W
                                      wazzu @geoffroff
                                      @geoffroff
                                      I had the same problem and I also had a shorter ID than the example. And of course, the status stay on “Loading tasks” for ever.
                                      Finally, to solve this and get the full length link, I’ve done the following :
                                      • create a share link from the list and open it
                                      • click on “Sign in to join list”
                                      • on next windows, click on “open”
                                        I finally have an error “List not found” but in the url is the correct ID which is working as ListID, e.g :
                                        https://to-do.live.com/tasks/AQMkADAwATMwNAItYmQyZS0wNnYxLTAwAi0wMAoALgAAAwyBXwAxHLZDhD1s2yT7wLoBAIZRCieiy1tMpuO70ZBr_R8AA3lr_WoAAAA=
                                      Hope it helps,
                                      Cheers,
                                      G 1 Reply Last reply
                                      • Z
                                        zolabus
                                        HI on the refresh token I have this error
                                        curl: (6) Could not resolve host:
                                        {“error”:“invalid_request”,“error_description”:“AADSTS900144: The request body must contain the following parameter: ‘grant_type’.\r\nTrace ID: c89030f5-7596-4716-b56b-baafdc670100\r\nCorrelation ID: 3c6c0d5a-8928-47f9-8916-30fb1a369a8e\r\nTimestamp: 2020-04-24 23:29:45Z”,“error_codes”:[900144],“timestamp”:“2020-04-24 23:29:45Z”,“trace_id”:“c89030f5-7596-4716-b56b-baafdc670100”,“correlation_id”:“3c6c0d5a-8928-47f9-8916-30fb1a369a8e”,“error_uri”:“https://login.microsoftonline.com/error?code=900144”}curl: (6) Could not resolve host:
                                        curl: (6) Could not resolve host: application
                                        ‘client_id’ is not recognized as an internal or external command,
                                        operable program or batch file.
                                        ‘scope’ is not recognized as an internal or external command,
                                        ‘redirect_uri’ is not recognized as an internal or external command,
                                        ‘client_secret’ is not recognized as an internal or external command,
                                        • G
                                          geoffroff @wazzu
                                          @wazzu Excellent worked a treat… ToDo didn’t like the link (List not Found) but when it returned to screen the list had the long ID. I amended the config file and worked like a charm… Thanks G
                                          • T
                                            thobach @andyyy
                                            @andyyy The call seems to be missing some parameters, please check the full command line from https://github.com/thobach/MMM-MicrosoftToDo/blob/master/README.MD, thanks!
                                            • 2 / 3
