    Microsoft To-Do (wunderlist replacement?)
    45 Posts 17 Posters 35.3k Views 19 Watching
    • T
      thobach
      I will look into it the next days. Benefits of using To Do from Microsoft is the easy migration from Wunderlist and very similar look and feel.
      • T
        thobach
        I created a new module for Microsoft To Do at https://github.com/thobach/MMM-MicrosoftToDo. The migration from Wunderlist to Microsoft To Do was quite seamless.
        @joela85 @binderth @D90 Could you please test it and provide me some feedback? Thanks!
        • T
          ThaliaFromPrussia
          I implemented it today and it works like a charm! Thank you very much!
          Is it possible to sort the tasks in different ways?
          Can I set the alignment to left side in the right side panel? Maybe in CSS?
          alt text
          • T
            ThaliaFromPrussia @ThaliaFromPrussia
            Nevermind, found it out for myself :smiling_face:
            You just need to add this in custom.css and it works:
            .MMM-MicrosoftToDo .module-content {
                text-align: left;
            Bild Text
              binderth @thobach
              @thobach thanks for your effort!
              I just migrated my wunderlist to ToDo (which went flawlessly) and now I’d like to authenticate ToDo as you described on github.
              first: I think, the URL is broken (spaces here: https://github.com/thobach/MMM-MicrosoftToDo#authorization-code-generation-code).
              only after replacing the whitespaces with “%20” it worked and I got the code.
              after that - I got all the info - but still no entries.
              logfile-out:
              [22:22:45.809] [LOG]    Connecting socket for: MMM-MicrosoftToDo
              [22:22:45.811] [LOG]    MMM-MicrosoftToDo helper started ...
              but the mirror only shows “Lade Einträge…” (loading entries).
              T T 3 Replies Last reply Reply Quote 0
                binderth
                apart from getting it to work, in what intervals does the module refreshs on the list? and could you also implement the “fade-option”? looks just cool! ;)
                • T
                  ThaliaFromPrussia @binderth
                  @binderth This is the problem I had first too. Had a c&p error in one of the tokens. Just do it again, for me it worked because I received other codes and now it loads everything.
                    binderth @ThaliaFromPrussia
                    @ThaliaFromPrussia jepp, did that (the client_id and stuff stays the same, but code regenerates. or did you delete your App as a whole?
                    • T
                      @binderth From the point with Azure on, including a new client ID.
                      the refresh time is very fast. You set up a new task and within a few seconds it appeares on the screen.
                        @ThaliaFromPrussia ok - still nothing new, did a complete new App now.
                        is there a way to get more Loginfos? right now I only get the helper and stuff in the log, but nothing more. no Authentication error or something, which would point me in the right direction…
                        T M 2 Replies Last reply Reply Quote 0
                        • T
                          @binderth I can only guess that you’ll have a typo somewhere. Maybe someone else near you can compare what you got and what you typed?
                          • T
                            @binderth said in Microsoft To-Do (wunderlist replacement?):
                            For me the link worked as it is. What whitespaces do you mean?
                            This might be helpful:
                            @sdetweil said in no result from mvgmunich modul:
                            @Babene1 open the developers window, using the keyboard, ctrl-shift-i, select the tab labeled ‘console’ and then scroll up… to find any errors (usually red text)
                            you can also filter to messages from a single module, by putting some part of its unique name into the file labeled ‘filter’, like mvgm
                            let us know what u find
                            if you use pm2 to manage the mirror runtime, you might also look at the logs, by doing
                            pm2 logs
                              mherke @binderth
                              @binderth
                              …same issues here. i can’t get it running and i am missing an option to analyse the problem :(
                                Jan
                                Hi. I successfully impemented your module. Thx for you effort! I have one question: Is there any possibility to get data for several lists and sort them under the name of the list ? (like before with Wunderlist) .
                                • A
                                  andyyy
                                  I am having trouble setting up this module. At the point refresh token generation I am failing.
                                  https://github.com/thobach/MMM-MicrosoftToDo/#refresh-token-generation-refresh-token
                                  1). Open terminal app -> I tried the windows console, powershell and secure shell (on the PI), but everywhere I receive just errors as output.
                                  Can someone give some guidance. Thanks.
                                  • T
                                    thobach @andyyy
                                    @andyyy What error message do you get? Are you on Windows 10 which should have curl pre-installed? I updated the readme file to replace the space symbols with %20 as that seemed to have caused issues for some. Please make sure to preserve the ’ symbol at the end of the call.
                                    • T
                                      thobach @binderth
                                      @binderth The refresh happens every 60s. I don’t plan to implement a fade-option, sorry, it would require quite some effort given the current implementation.
                                      • T
                                        thobach @Jan
                                        @Jan You’re welcome. Have you tried adding the module multiple times in the config file with different listId values?
                                        • T
                                          thobach @binderth
                                          @binderth Did the tips from @ThaliaFromPrussia (https://forum.magicmirror.builders/post/68615) work for you to see what error you are getting on the magic mirror front-end?
                                            Jan @thobach
                                            @thobach Thx for your reply. Your solution has not exactly the effect what i want, but it works fine for me ;-)
