    Microsoft To-Do (wunderlist replacement?)
    45 Posts 17 Posters 36.1k Views 19 Watching
      D90 @justjim1220
      @justjim1220 said in Microsoft To-Do (wunderlist replacement?):
      Todoist is a module for ToDo’s
      works better than Wunderlist.
      Again, that’s not at all what was asked at all.
      They are asking for a module which works with Microsoft To-Do
      https://todo.microsoft.com/
      • joela85J
        joela85
        So it looks like Microsoft are starting to replace Wunderlist with Microsoft To Do.
        Wondering if anyone has seen a new module for this?
        Would like to replace my Wunderlist with this if they’re going to switch off Wunderlist.
        It looks like you should be able to use “Outlook Task REST API reference (version 2.0)” for it. But I don’t know enough about programming to make the module myself.
        Reply Quote 3
        • T
          thobach
          I will look into it the next days. Benefits of using To Do from Microsoft is the easy migration from Wunderlist and very similar look and feel.
          • T
            thobach
            I created a new module for Microsoft To Do at https://github.com/thobach/MMM-MicrosoftToDo. The migration from Wunderlist to Microsoft To Do was quite seamless.
            @joela85 @binderth @D90 Could you please test it and provide me some feedback? Thanks!
            binderthB 1 Reply Last reply
            • T
              ThaliaFromPrussia
              I implemented it today and it works like a charm! Thank you very much!
              Is it possible to sort the tasks in different ways?
              Can I set the alignment to left side in the right side panel? Maybe in CSS?
              alt text
              T 1 Reply Last reply
              • T
                ThaliaFromPrussia @ThaliaFromPrussia
                Nevermind, found it out for myself :smiling_face:
                You just need to add this in custom.css and it works:
                .MMM-MicrosoftToDo .module-content {
                    text-align: left;
                Bild Text
                • binderthB
                  binderth @thobach
                  @thobach thanks for your effort!
                  I just migrated my wunderlist to ToDo (which went flawlessly) and now I’d like to authenticate ToDo as you described on github.
                  first: I think, the URL is broken (spaces here: https://github.com/thobach/MMM-MicrosoftToDo#authorization-code-generation-code).
                  only after replacing the whitespaces with “%20” it worked and I got the code.
                  after that - I got all the info - but still no entries.
                  logfile-out:
                  [22:22:45.809] [LOG]    Connecting socket for: MMM-MicrosoftToDo
                  [22:22:45.811] [LOG]    MMM-MicrosoftToDo helper started ...
                  but the mirror only shows “Lade Einträge…” (loading entries).
                  T T 3 Replies Last reply
                  • binderthB
                    binderth
                    apart from getting it to work, in what intervals does the module refreshs on the list? and could you also implement the “fade-option”? looks just cool! ;)
                    • T
                      ThaliaFromPrussia @binderth
                      @binderth This is the problem I had first too. Had a c&p error in one of the tokens. Just do it again, for me it worked because I received other codes and now it loads everything.
                      • binderthB
                        binderth @ThaliaFromPrussia
                        @ThaliaFromPrussia jepp, did that (the client_id and stuff stays the same, but code regenerates. or did you delete your App as a whole?
                        • T
                          @binderth From the point with Azure on, including a new client ID.
                          the refresh time is very fast. You set up a new task and within a few seconds it appeares on the screen.
                          • binderthB
                            @ThaliaFromPrussia ok - still nothing new, did a complete new App now.
                            is there a way to get more Loginfos? right now I only get the helper and stuff in the log, but nothing more. no Authentication error or something, which would point me in the right direction…
                            T M 2 Replies Last reply
                            • T
                              @binderth I can only guess that you’ll have a typo somewhere. Maybe someone else near you can compare what you got and what you typed?
                              • T
                                @binderth said in Microsoft To-Do (wunderlist replacement?):
                                For me the link worked as it is. What whitespaces do you mean?
                                This might be helpful:
                                @sdetweil said in no result from mvgmunich modul:
                                @Babene1 open the developers window, using the keyboard, ctrl-shift-i, select the tab labeled ‘console’ and then scroll up… to find any errors (usually red text)
                                you can also filter to messages from a single module, by putting some part of its unique name into the file labeled ‘filter’, like mvgm
                                let us know what u find
                                if you use pm2 to manage the mirror runtime, you might also look at the logs, by doing
                                pm2 logs
                                  mherke @binderth
                                  @binderth
                                  …same issues here. i can’t get it running and i am missing an option to analyse the problem :(
                                    Jan
                                    Hi. I successfully impemented your module. Thx for you effort! I have one question: Is there any possibility to get data for several lists and sort them under the name of the list ? (like before with Wunderlist) .
                                    • A
                                      andyyy
                                      I am having trouble setting up this module. At the point refresh token generation I am failing.
                                      https://github.com/thobach/MMM-MicrosoftToDo/#refresh-token-generation-refresh-token
                                      1). Open terminal app -> I tried the windows console, powershell and secure shell (on the PI), but everywhere I receive just errors as output.
                                      Can someone give some guidance. Thanks.
                                      • T
                                        thobach @andyyy
                                        @andyyy What error message do you get? Are you on Windows 10 which should have curl pre-installed? I updated the readme file to replace the space symbols with %20 as that seemed to have caused issues for some. Please make sure to preserve the ’ symbol at the end of the call.
                                        A 1 Reply Last reply
                                        • T
                                          thobach @binderth
                                          @binderth The refresh happens every 60s. I don’t plan to implement a fade-option, sorry, it would require quite some effort given the current implementation.
                                          M 1 Reply Last reply
                                          • T
                                            thobach @Jan
                                            @Jan You’re welcome. Have you tried adding the module multiple times in the config file with different listId values?
                                            J 1 Reply Last reply
