    MirrorMirrorOntheWall Alexa Skill trouble
    17 Posts 8 Posters 12.9k Views 8 Watching
      subminimal
      THAT DID IT! The skill is working fine! Thanks SO much! I feel like it’s the last part here Im a little unclear on as well… do I put the whole MirrorMirroronthewall folder into the modules folder with certs, then add the module to config.json file? What are the last few steps to get this puppy in gear? Its a little fuzzy in the docs. THANK YOU A MILLION TIMES!!!
        subminimal
        I’m SO close. Alexa does the “Yes my queen” intro, and says she is playing a video for me. But I don’t see a video, and I can’t make changes to the layout verbally either. I know I’m mucking up installing the actual module now that the skill is working.
        • T Offline
          torresfm
          Haven’t tried configuring the MM module yet but it says to just copy the cert folder from the Alexa skill to the module directory and make sure that the cert paths are correct in the modules mirrormirror.js file. I’ll try it out sometime next week.
            subminimal
            Thank you for the reply. This is my first 3rd party module (I picked a doozy lol) do I have to place the module master folder in /modules as well? Thanks again my friend you’re a lifesaver.
            • T Offline
              torresfm
              @subminimal
              In the modules mirrormirror.js file you need to add the same host line with the ios endpoint. If youve copied the certs to the module folder, added the module in config/config.js, and run npm install in the module folder to install dependencies then you should be all set.
                subminimal
                That did it nearly 100%!!! The videos play, everything is correct… the only thing is when I use MirrorMirrorOnTheWall to bring up an image… I’m getting the endpoint error again! So weird… Words and videos work just fine, but I can’t bring up images. I’ve checked the API key and CSE ID is correct in keys.json, but still the same. Weird. I mean, I suppose it’s not crazy important, just images… but you know, always striving for 100% functionality. Is there a place that host line needs to be added in google-images somewhere? Hmmm…
                Anyway, torresfm THANKYOU SO MUCH for getting me as far as you have!!! I think the author should be made aware of the endpoint issue. If you stumble across a fix for the images portion of the module let me know!
                X 1 Reply Last reply Reply Quote 0
                • T Offline
                  torresfm
                  I did’nt have this problem. You should check if the CSE ID and API key is correct and make sure the youtube and cse apis are in different projects.
                  • X Offline
                    XerqJon @subminimal
                    @subminimal I ran into the same problem you did and for me it was simply because I forgot to enable image search in my CSE - did you ever get this working? That may be it.
                    • K Offline
                      kbostick88
                      I am also have an issue with this module, but my issue is getting it installed. The instructions say “copy all your credential files, then go to your local copy of this repo, and paste them inside the certs folder (which is inside the src folder)” but I can not find a certs folder inside the src folder. Can someone explain this to me
                      • L Offline
                        lodesmets
                        Thanks that fixed that error, I still get “RequestId: Process exited before completing request” error, any idea?
                        • richland007R Offline
                          richland007
                          @torresfm Here is the issue i have now after the Mirror responds with hello my queen what can i do for you than when i ask about anything it says there is an error with your skills response and nothing happens
                          here is the error that i get on Lamda CloudWatch after that
                          Any ideas on how to solve this
                          Denis
                            dcalix @richland007
                            @richland007 Did you have any luck on this?
                            richland007R 1 Reply Last reply Reply Quote 0
                              richland007 @dcalix
                              @dcalix No nothing in addition to the above other errors have arisen… read here from the beginning for more details
                              https://forum.magicmirror.builders/topic/8569/mmm-mirrormirroronthewall-installation-issue/63?page=7
