    MirrorMirrorOntheWall Alexa Skill trouble
    17 Posts 8 Posters 13.4k Views 8 Watching
      subminimal
      Thank you for the reply. This is my first 3rd party module (I picked a doozy lol) do I have to place the module master folder in /modules as well? Thanks again my friend you’re a lifesaver.
      • T
        torresfm
        @subminimal
        In the modules mirrormirror.js file you need to add the same host line with the ios endpoint. If youve copied the certs to the module folder, added the module in config/config.js, and run npm install in the module folder to install dependencies then you should be all set.
          subminimal
          That did it nearly 100%!!! The videos play, everything is correct… the only thing is when I use MirrorMirrorOnTheWall to bring up an image… I’m getting the endpoint error again! So weird… Words and videos work just fine, but I can’t bring up images. I’ve checked the API key and CSE ID is correct in keys.json, but still the same. Weird. I mean, I suppose it’s not crazy important, just images… but you know, always striving for 100% functionality. Is there a place that host line needs to be added in google-images somewhere? Hmmm…
          Anyway, torresfm THANKYOU SO MUCH for getting me as far as you have!!! I think the author should be made aware of the endpoint issue. If you stumble across a fix for the images portion of the module let me know!
          X 1 Reply Last reply
          • T
            torresfm
            I did’nt have this problem. You should check if the CSE ID and API key is correct and make sure the youtube and cse apis are in different projects.
            • X
              XerqJon @subminimal
              @subminimal I ran into the same problem you did and for me it was simply because I forgot to enable image search in my CSE - did you ever get this working? That may be it.
              • K
                kbostick88
                I am also have an issue with this module, but my issue is getting it installed. The instructions say “copy all your credential files, then go to your local copy of this repo, and paste them inside the certs folder (which is inside the src folder)” but I can not find a certs folder inside the src folder. Can someone explain this to me
                • L
                  lodesmets
                  Thanks that fixed that error, I still get “RequestId: Process exited before completing request” error, any idea?
                  • richland007R
                    richland007
                    @torresfm Here is the issue i have now after the Mirror responds with hello my queen what can i do for you than when i ask about anything it says there is an error with your skills response and nothing happens
                    here is the error that i get on Lamda CloudWatch after that
                    Any ideas on how to solve this
                    Denis
                    D 1 Reply Last reply
                      dcalix @richland007
                      @richland007 Did you have any luck on this?
                      richland007R 1 Reply Last reply
                      • richland007R
                        richland007 @dcalix
                        @dcalix No nothing in addition to the above other errors have arisen… read here from the beginning for more details
                        https://forum.magicmirror.builders/topic/8569/mmm-mirrormirroronthewall-installation-issue/63?page=7
