    Switch off the display - how to ?
    3 Posts 3 Posters 1.6k Views 3 Watching
      A Former User
      As of now I use a pir-sensor to switch the display on and off (hdmi).
      But I cannot suppress the screensaver - does not look good .
      Via my smarthome system ( fhem ) I could use a remote switch to power the display on and off.
      I could do this sending a (URL)-command to the system.
      How can I achieve that ?
      idoodlerI 1 Reply Last reply
      • idoodlerI
        idoodler Module Developer @Guest
        @howi42 What module do you use for your PIR sensor? Some modules are able to directly control a Relais for the monitors power supply.
        • G
          grantc66
          Not sure if I understand the issue.
          You want to inhibit the screensaver?
          I have a script in the startup:
          #!/bin/sh
          xset -dpms # disable DPMS (Energy Star) features.
          xset s off # disable screen saver
          xset s noblank # don’t blank the video device
          unclutter & # loose the cursor
          This works for me on a Pi0 which doesn’t have a desktop, might be different if you have a console loaded at boot.
          Others have mentioned installing the screensaver app and using that to inhibit the display blanking.
          If you want to switch the display from a phone, try RasPiCheck (available from Google Play) & set up a couple of console commands:
          vcgencmd display_power 1 # for on
          vcgencmd display_power 0 # for off
          you’ll need SSH switched on in the Pi config & know the Pi ip-address.
