    MMM-Assistant Jarvis.umdl set up
    3 Posts 2 Posters 1.8k Views 2 Watching
      meisch23
      I just got my MMM-Assistant fully working finally and the last step I would like to do is change my assistant .umdl to jarvis instead of snowboy. I see that you need to put 2 sensitivities in for jarvis and also change the ApplyFrontend to true. I am completely lost on how to do this, I don’t know a whole lot about coding so bare with me please! Would these changes just be a matter of editing the module in the config.js or do I need to go somewhere else to make the changes?
      Thanks in advance!
        Plachu
        Hi, I think you have to change it in config.js file (in MagicMirror dir) like:
        file: “resources/jarvis.umdl”,
        sensitivity: 0.8, 0.80,
        hotwords : “ASSISTANT” //One of models should be “ASSISTANT”
        But I’m not sure. BTW what ver of MM are u using? Couse I can’t get it work with 2.4.1…
          meisch23 @Plachu
          @plachu I’m using 2.4.1
          It recognizes the jarvis hotword with
          file: ‘resources/u-models/jarvis.umdl’,
          sensitivity: ‘0.8,0.80’,
          hotwords: [‘jarvis’,‘jarvis’]
          but the microphone turns red right after recognizing the hotword and doesn’t do anything afterwards.
