    Screen cannot rotate after upgrade to 2.4.0
    4 Posts 1 Posters 2.3k Views 1 Watching
      Sun
      Yesterday, after update to v2.4.0 and follow the wiki Load normally with rotate-1
      Today, boot normally but the screen both on rp3 frontend and magic mirror didn’t rotate at all.
      Where do I need to re-correct this?
        Sun @Sun
        After redo all the wiki step and reboot. Rotate correctly. Not sure if I have to set every time?
          Sun @Sun
          This time I try to upgrade another mirror got this
          pi@SAMUIMIRROR:~/MagicMirror $ git pull && npm install
          Updating 60b9a5b…6aa156d
          error: Your local changes to the following files would be overwritten by merge:
          modules/default/alert/alert.js
          modules/default/calendar/README.md
          modules/default/calendar/calendar.js
          modules/default/calendar/calendarfetcher.js
          modules/default/compliments/README.md
          modules/default/compliments/compliments.js
          modules/default/currentweather/currentweather.js
          modules/default/newsfeed/README.md
          modules/default/newsfeed/fetcher.js
          modules/default/newsfeed/newsfeed.js
          modules/default/newsfeed/node_helper.js
          modules/default/weatherforecast/README.md
          modules/default/weatherforecast/weatherforecast.js
          package-lock.json
          translations/de.json
          translations/en.json
          translations/it.json
          translations/nl.json
          translations/pt_br.json
          translations/translations.js
          translations/zh_cn.json
          translations/zh_tw.json
          Please commit your changes or stash them before you merge.
          Aborting
            Sun
            Read and Read and found the solution regarding cannot upgrade to 2.4.0
            git reset --hard; git clean -df;
