    Magic Mirror not starting after upgrade on Raspberry Pi2
    1 Posts 1 Posters 904 Views 1 Watching
    • H
      hrjmsh
      I upgraded MM today to version 2.4.1 on my raspberry Pi 2. I did the npm install but now getting the following error:
      1 verbose cli [ ‘/usr/bin/nodejs’, ‘/usr/bin/npm’, ‘start’ ]
      2 info using npm@1.4.21
      3 info using node@v4.8.2
      4 verbose run-script [ ‘prestart’, ‘start’, ‘poststart’ ]
      5 info prestart magicmirror@2.4.1
      6 info start magicmirror@2.4.1
      7 verbose unsafe-perm in lifecycle true
      8 info magicmirror@2.4.1 Failed to exec start script
      9 error magicmirror@2.4.1 start: sh run-start.sh
      9 error Exit status 127
      10 error Failed at the magicmirror@2.4.1 start script.
      10 error This is most likely a problem with the magicmirror package,
      10 error not with npm itself.
      10 error Tell the author that this fails on your system:
      10 error sh run-start.sh
      10 error You can get their info via:
      10 error npm owner ls magicmirror
      10 error There is likely additional logging output above.
      11 error System Linux 4.14.52-v7+
      12 error command “/usr/bin/nodejs” “/usr/bin/npm” “start”
      13 error cwd /home/pi/MagicMirror
      14 error node -v v4.8.2
      15 error npm -v 1.4.21
      16 error code ELIFECYCLE
      17 verbose exit [ 1, true ]
